Old 05-13-2006, 10:19 AM   #15
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by Metta Photo
Hi, I'm brand new to forum. Were your old tires 7.00 X 15? I like the wheels that you indicate.
Thanks, Will
Will,
Originally, the tires on both of my coaches were 7.00x15 bias ply tires. I changed wheels on both trailers, and went to 225/75R15 Marathon tires. The wheels I linked to are a standard trailer wheel, with zero offset. It should fit all 12in brake drums perfectly fine. You will loose some ride height when changing to radials.
Welcome to the forums!
Uwe
www.area63productions.com
Old 05-13-2006, 11:33 AM   #16
1960 24' Tradewind
santa barbara , California
Uwe, thanks for your great reponse to my questions directed to you .Sounds like your rig works fine without them ,I see that the torsion axles have sort of a built in cushion that makes them smooth ,maybe not as easily bounced around .I refer to shocks soley as a device that controls the bounce from the tire/wheel assembly as it rebounds from an obstruction in the road of whatever type ,controlling the tire keeping it in contact with the road at all times .I can,t say that the torsion can controll this alone.Anyway Ill stick with the shocks . your correct that the solid axle cannot be compared directly with the torsion in how the ride will be ,however,the shock provides the same dampening effect it needs .Other torsions dont come with shock brackets because they dont know where to mount them ,It appears that everyone is welding them on from the axle threads I have seen.
Good postings and responses here!
Scott
scottanlily is offline   Reply With Quote
Old 05-13-2006, 07:52 PM   #17
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Btw., Airstream does not put shocks on the 22ft trailers, for some reason. The 22ft trailers have Dexter axles.
The 19ft trailers have shocks. The 25ft and bigger units have shocks...the new 23 that I saw did not have shocks, unless I overlooked them.
I could not identify if the 06 trailers had Dexter or Henschen axles, but the bigger ones all had Dexter drums and did have shocks on them. BTW, I am reasonable sure that the new Airstream wheels are identical to the ones sold here: www.trailertiresandwheels.com. The factory installation and care stickers are the same as the ones found on the wheels that I bought for my 63 Overlander. ( Since this is actually a wheel thread....)
Uwe
Old 05-13-2006, 08:18 PM   #18
bimi's Avatar
Split rims?
I am getting ready to replace my tires, but how do I know if I have the split rims? My trailer is a 71 ambassador. Anyone know?
2002 Dodge 1500 4x4 quad cab, 1971 Ambassador International, 1 Bad-Boy Tote Tank
bimi is offline   Reply With Quote
Old 05-13-2006, 08:28 PM   #19
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
My 1971 TradeWind did not have split rims, but rather conventional steel wheels with baby moon hub caps.
Uwe
Old 05-13-2006, 08:54 PM   #20
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
I doubt it
You can tell if they're split rims by just looking at them..
I have the original wheels on my 64GT and, will post pictures for you later..
IT'S RAINING WAY TOO HARD OUT NOW TO DO IT..lol
BTW, the splits rim are very dangerous..
Please don't attempt to deflate the tires as the split rims are known to fly off and cause severe bodily harm~!
If you must, always deal with them behind a safety cage to contain the rims ~!!
But as I said, I seriously doubt that you have split rims on your 71..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-14-2006, 08:39 PM   #21
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I do not believe split rims were used on any 70's built Airstreams. I thought split rim usage was discontinued in the 60's. Mid 60's if I am not mistaken.
And most if not all tire stores will not reuse them. They will remove from the vehicle and dispose of them or ask you to do the same.
>>>>>>>>>>>>>>>>>>>>>>>Action
Old 05-15-2006, 08:46 PM   #22
bimi's Avatar
I will check
Thank you for the info. I will check it out, but I really don't remember seeing anything unusual, so they probably have regular rims. It would be interesting to know just exactly when the split rims were discontinued.
Old 05-16-2006, 08:43 AM   #23
Somewhere , Indiana
For what it is worth -
I worked in the trailer axle industry for a number of years and can say that Airstream is the only company to put shocks on a torsion axle. I too feel it is un-needed.
On a spring axle I have seen shocks used by high-end RV manufacturers.
We had over 500 customers that ordered torsion axles from ground support equiptment to portable light towers - NONE used a shock. Several of these customers had more folks in the Engineering Department than Airstream has in manufacturing. Just two cents from a retired axle dude!
Regards,
Henry
axleman is offline   Reply With Quote
Old 05-16-2006, 04:06 PM   #24
1965 28' Ambassador
Long Branch , New Jersey
Thanks, Will
Hey Will,
To answer your question. Yes, the tires are 700 X15. Do you have any pictures of your airstream? we don't yet have a digital camera so we can't post any pix yet.
SuenJohn
suenjohn is offline   Reply With Quote
Old 05-22-2006, 07:22 PM   #25
1990 34' Excella
Windcrest , Texas
Rims for 1990 Excella 1000, 34 ft
Hello everyone,
I've been watching this thread and wanted to get your input on what rims to put on our Airstream. I believe a previous owner switch out the rims with steel ones since they've been painted over and look pretty rough.
We'd like to replace them with aluminum rims and the plate on the side of the trailer states that the wheels are 15 X 6. I guess this means they're 15" with 6 lug nuts, since I counted 6 lugs. By the way, our 34' has three axles.
When researching rims I've seen all kinds of 'bore' sizes so can anyone help me with what type to put on? Many thanks.
Mitch
Swanny is offline   Reply With Quote
Old 05-22-2006, 07:44 PM   #26
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Swanny
Hello everyone,
Mitch
Mitch, 15x6 is the height and width of your wheel. It is a 15" diameter wheel, 6" wide. Bolt pattern should be 6-5 1/2", or six bolt, 5 1/2" pattern, and yours should have a zero offset, and 2500 pound capacity.
Old 05-22-2006, 08:04 PM   #27
1990 34' Excella
Windcrest , Texas
Thanks Terry
Terry,
Do these rims appear to have what you are suggesting?
http://www.trailertiresandwheels.net...product/AW1511
Mitch
Old 05-22-2006, 11:37 PM   #28
1960 24' Tradewind
I would say then concerning the shock discussion that airstream felt the need to put shocks on their coaches for all the years they have .Probably to give it the smooth ride they have .I cant imagine that they wasted thousands of dollars year after year for no good reason .Airstream is in fact the best trailer made ,we all agree on that I think .I wouldn't bother putting shocks on a utility unit trailers either ,they aren't going to waste any money doing that ,in addition to the fact that those 500 customers are not ordering an airstream trailer .I believe airstream has it covered in the manafacturing department and know what they are doing.
Scott
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
