Old 07-31-2014, 04:16 PM   #1
1968 28' Ambassador
Livingston , Montana
Replacement Hub for '68 Ambassabor
I need to locate a replacement hub for my '68 Ambassador. The plate the magnet rides against came loose and locked the rear wheel on driver's side during last trip. The plate can't be reattached because the holes are "wallowed out". Can't afford new axles yet, so any help locating a 12" hub with 6 studs would be appreciated.
JokerDJD
JokerDJD is offline   Reply With Quote
Old 07-31-2014, 07:19 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Almost any place that sells trailer parts should have no trouble selling you a 12"x2" hub and drum. Just make sure the drum is for the lower weight, rather than the 8,000 pound hub.
Looking for a replacement hub to fit my tag axle Mr. D Classic Motorhomes 8 04-10-2010 03:36 AM
'78 Landyacht Ambassabor door latch Kandy Doors & Locks 7 06-15-2006 10:10 PM
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 11:46 AM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
