Old 05-07-2003, 10:11 AM   #1
minglewood's Avatar
Question Replace wheels?
Hi all, I just bought my first Airstream (1972 27' Overlander) and I saw on the Inland RV page they reccommend when going from 6 ply to 8 ply tires the wheels should be replaced. The current wheels look fine, but I need new tires. Is replacement really necessary or just a bit of safety overkill?
Bill
minglewood is offline   Reply With Quote
Old 05-07-2003, 10:22 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Wheels
Hi Bill,
I have a trailer of similar age, even though mine is a little smaller.
I think the idea is to do a very thorough inspection of the wheels with the tires removed, before you can make an intelligent decision.
If the wheels show no dents or cracks, and look rust free, then it might not be a problem to go to D-rated (8ply) tires.
Also, make sure the wheels are original equipment or equivalent, not mismatched or of lesser quality.
I had to replace my wheels because they were very rusty, and the new tires would not hold air reliably. When I removed the tires I saw a lot of rust inside the wheel, along the welds and in the wheel bolt area. My old wheels would have eventually caused a problem, from the looks of them.
If in doubt, just buy new wheels and tires, and keep the very best one of the old ones for a spare, perhaps.
Good Luck!
Uwe
www.area63productions.com
Old 05-07-2003, 11:40 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
New tires
Bill,
Congrats on your purchase. And special congrats on getting an Overlander!
So why do you want to go to 8 ply (Load range D) tires? And are the current wheels steel or cast?
>>>>>>>>>>>>>>>>>>>>>>>>Action
Old 05-07-2003, 06:03 PM   #4
Minglewood.
The recommendation came from the manufacturer of the wheels, not us, along with the warning that the wheels more than likely will split. This happens on wheels that have several years on them.
We just provided that information for owners perusal.
inlandrv.com
Old 05-08-2003, 06:47 AM   #5
minglewood's Avatar
6 ply ok?
Thanks for the replies folks. I guess I'll just go with new 6 ply marathons, provided the wheels are in good condition. This should be ok, right?
Bill
Old 05-08-2003, 08:20 AM   #6
Six ply is great.
Anything less would be hazardeous.
inlandrv.com
Tires & Wheels for a '66 Overlander 66Overlander Tires 16 05-28-2004 11:20 PM
16" wheels for my A/S Chipster Our Community 2 03-18-2004 01:11 AM
Wheels for 1961 Overlander David Hall Wheels, Hubs & Bearings 19 01-29-2004 07:24 AM
need to replace the wheel...are there jacking points? 60traveler Jacks, Stabilizers, Lifting and Leveling 1 06-25-2003 03:05 PM
alloy wheels T&R Wheels, Hubs & Bearings 3 05-19-2003 06:52 PM
