Old 03-20-2010, 07:30 PM   #1
1978 28' Ambassador
Savannah , Georgia
Repainting rusty wheels
This is "how I did mine" to paint rusty wheels. I am NOT an expert and this is just my experience.
1) These are the tires that had been in the marsh for the last eight years.
2) I had the tires removed and washed off all the dirt and loose rust.
Name:	Wheels from AS.jpg
Name:	Wheel with tire removed.jpg
Skamper1 is offline   Reply With Quote
Old 03-20-2010, 07:34 PM   #2
1978 28' Ambassador
Savannah , Georgia
3) PO has welded a bolt to the rim to secure the hubcaps. I ground off the bolt and used wire wheel on drill to remove loose rust.
4) Cleaned wheels with laquer thinner and then sprayed with phosphoric acid to neutralize the rust. Left acid on for 24 hours.
Name:	Wheel wire brushed.jpg
ID:	98491   Click image for larger version
Name:	Wheel sprayed with phosphoric acid.jpg
Old 03-20-2010, 07:50 PM   #3
1978 28' Ambassador
Savannah , Georgia
5) Wiped acid with damp rag to remove white powder residue.
6) Primed with rustoleum dark gray primer.
7) Three light coats of High Performance Gloss Black Rustoleum. Within one hour.
8) Wheels and new tires back on AS.
Will take time to work on hubs and wheel well now that I have the AS home.
Cost (4 wheels): acid $15, wire brushes $5, primer $11, black paint $16
Total $47 for materials. Labor 12 hours.
It has been pointed out that I could have bought new wheels with no rust and no history of "bad balance" for $200. This is how I chose to do mine. Time will tell how well I did.
Jack
ID:	98493   Click image for larger version
Name:	Wheel primed with dark gray primer.jpg
Name:	Wheel painted with gloss black.jpg
ID:	98495   Click image for larger version
Old 03-20-2010, 08:16 PM   #4
Keep in mind that rust on wheels weakens them, along with the applied acid.
How weak?
Depends on how much rust was removed, and perhaps how much the acid removed as well.
Old 03-20-2010, 11:11 PM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
How weak?
Phosphoric acid doesn't remove steel at any appreciable rate. It forms hard black ferric phosphate, FePO4 with rust which inhibits further corrosion; it is a very common treatment before painting any bare steel.
From the photo, the rust appears to be of of only cosmetic concern.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-20-2010, 11:25 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Your like me
You do the things like I do....hours of work, expensive parts and supplies and numerous trips to the suppliers. The result is very nice.
A new, already painted rim is 30 dollars....
Old 03-21-2010, 09:46 AM   #7
1972 Travelux Princess 25
Cobourg , Ontario
Can you buy new rims of the exact same style as original for $30? If so it's a bargain.
Most tires shops will bead blast and paint your wheels for $20 or $30. They can also true up the wheel and make sure it is straight and balanced.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Repainting an Argosy murphytom Clearcoat, Exterior Paint & Trim 1 06-25-2007 10:38 AM
repainting rusty hitch? pinkflamingoes Clearcoat, Exterior Paint & Trim 3 08-15-2004 01:18 PM
Repainting 77 R GO C MH Clearcoat, Exterior Paint & Trim 3 02-29-2004 02:09 PM
Rusty wheels Airstream 1975! Wheels, Hubs & Bearings 1 02-29-2004 12:09 PM
Repainting with Zolatone 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 3 06-10-2002 09:58 AM
