Old 03-30-2016, 09:29 AM   #29
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
cwf.... I think you have a very valid point. The bearings were installed correctly. It was the axle that was off. That would seem to affect the opposite side as well.
Sitting at a stop light some may notice that the car in front has a wheel/axle out of adjustment. It is at an angle. Tire wear is the FIRST indication, and then the wheel bearings pay for it.
In my poorer days to supplement car parts for my youthful attraction to rough idling cams and higher compression pistons and head work... I used a carpenter's level to adjust the front wheel suspension, so they were vertical. There is an angle specified by the design, but a front end alignment cost money.
If we all knew today from experience, repair and service shops would be out of business.
I do miss the grease under the fingernails and no two knuckles without skin missing... but youth spent being busy was a good alternative to sitting around today sending text messages and selfies to one another for recreation.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 03-30-2016, 10:55 AM   #30
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My 2008 Classic has the Dexter Nev-R-Lube bearings. Should I probably get them inspected now the trailer is 8 years old. The trailer saw minimal use when I purchased in 2013 and since then I've only take two long trips of 3000 miles each and short trips locally. I've probably put less than 10k miles.
Kelvin
Old 04-04-2016, 09:59 AM   #31
2013 25' Flying Cloud
san mateo , California
Nev-R-Lube
Warranty says 5 yrs or 100k miles for any defects.
dmand001 is offline   Reply With Quote
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
How do I get this off? (re: repacking bearings) Zstream Wheels, Hubs & Bearings 7 05-04-2008 08:58 AM
1st time repacking my wheel bearings Bill C. Axles 9 02-22-2008 07:49 PM
Repacking Wheel Bearings Buttercup Axles 38 05-07-2005 08:57 PM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
