Old 05-11-2010, 07:15 AM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Repacking the bearings how to...
I had read in the owners manual (some) about how to raise a wheel for changing a flat on this 70 model. My question is exactly how to go about doing it. My roomate said to let the air of the tire and the wheel would lift up. So what I am getting to here is how do we raise a wheel so we can repack the bearings? Does the wheel really need to be raised? and are there any videos you folks might have as a link that shows how the tires 'raise up' for maintenance . Thanks, Bill
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 05-11-2010, 07:36 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
wheel bearing work
Hi Bill,
The easy way to raise a wheel for work or a flat is to pull the trailer up onto an elevated surface..the wheel not being worked on is on the raised surface...this will leave the other one off the ground. There is a special made "chock" made specially for this purpose.....I use a couple 2 x 8 boards. (this is for tandem axle rigs) Be sure to block the wheels on the other side as a safety precaution. Swap to the other wheel to work on it.
There is a good video on Youtube on wheel bearing work too. It is a messy but easy job.
Old 05-11-2010, 07:40 AM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Make you a little ramp out of 2x6`s,pull 1 wheel up on it,and the other wheel will come off the ground,if you have a hard time getting the wheel out of the wheel well,you need new axles.
Always replace the seals,with the double lip seals.Clean the old bearing with diesel,gas or kerosene. If you don`t have a bearing packer,place a gob of grease in on hand,with the big side of the bearing keep pressing the grease thru the bearing until new grease comes out the small side.Dave
easyride is offline   Reply With Quote
Old 05-11-2010, 02:35 PM   #4
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
redhawkerII -
make your life as easy as possible - if you have a 2 axle AS just buy a set of 'lynx levellers'. i bought a set after doing a bit of research on ways to change a flat tire on an AS.
these are large orange plastic pieces that look like giant legos. they link together to form a stepped/pyramid shape.
you just put them in front or behind the tire you are NOT changing - then pull forward or back up onto them.
when the tire climbs them, the other tire/wheel raises high enough to change. remember to slightly loosen the lugs before raising the tire otherwise the wheel will spin.
its also a good idea to set your TV brake and put chocks around the off-side tires.
i used these 2 weeks ago to change a tire and they worked perfectly. a lot easier and safer than planks and they take up less than 1 sq.ft. of room.
note: there are yellow knock-offs available but your best bet is to buy the original.
good luck.
az-streamer
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Don’t Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 05-11-2010, 03:47 PM   #5
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hi Redhawker, I just did my bearings and rotated tires today, I use a bottle jack and place it between the tires and jack up the frame and both wheels come off the ground, pull both wheels do the bearings get yourself a (bearing buddy) makes life a lot easier and saves a lot of time, I also use a couple cans of parts cleaner in a spray can to wash all the old grease out of the bearing. Hope this helps. And of course use a jack stand for safety and do this on level ground.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-11-2010, 04:50 PM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If your axles are new or in good shape and have a good bit of suspension (movement) then the levelers or boards work great. If your axles are shot (very little suspension travel) getting the wheels out of the wheel well can be tough because they don't drop down any when raised. If that is the case, you may need to raise the axle you are working on a little higher off the ground to allow you to angle the tire when pulling it out of the wheel well. I didn't do a good job describing the issue, you will understand when you raise the trailer.
Good luck.
Also, use a good quality wheel bearing specific grease and like easyrider said use the good double lip grease seals.
Old 05-20-2010, 02:37 PM   #7
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
wheel bearing lube
how often would be prudent to repack wheel bearings on a new trailer...
thanks
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 05-20-2010, 07:33 PM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
thanks
The recommended interval is annually. The best time would be in the Spring, when you dewinterize the trailer. You can make a day job out of it, dewinterizing, checking and inflating tires, repacking wheel bearings and checking brakes, restocking the first aid kit, and in general making sure everything on the trailer is ready to go camping.
Old 05-20-2010, 07:34 PM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Generally, once a year, though I repack my bearings every two years.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-20-2010, 10:38 PM   #10
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
"A Shocking Brake story."
Marvin
thanks
Hi, I had a dealer do my bearing pack and brake inspection when my trailer was two years old. Three years later, I decided to do it myself. Wheel bearings should be good for many years with out repacking. And if you use your transmission to help slow you down, and don't abuse your brakes, your brakes should also last a very long time. I am going to say [my opinion] that you should be safe doing this job, every two years.
I also use a bottle jack on the axle mounting brackets and four jack stands. I pull all of the wheels off.
Now, I will recommend that you read my latest blog, "A Shocking Brake story" [click on blog under my avatar] and see what kind of surprizes you could encounter doing this job.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-21-2010, 04:26 AM   #11
Islander
wheel bearings
trailer is on road full time now,,,no ned to winterize as we are heading down the blacktop..
so under constant travel conditions..what would be prudent....
thanks
Kingfisher24
WBCCI 2541
4CU
Old 05-21-2010, 05:45 AM   #12
Well Preserved
1993 21' Sovereign
thanks
It would still be annually, unless you're towing from coast-to-coast every week for some reason. Then you would repack every 12,000 miles or so, and more to check the brakes than to keep the condensed moisture out of the grease like would occur if the trailer sat a lot. It also would give you a chance to rotate tires and check them for abnormal wear.
Old 05-21-2010, 06:24 AM   #13
richinny's Avatar
2011 34' Classic
i much rather do brake work than transmission work mut that might just be me.
Ricky
Old 05-21-2010, 01:34 PM   #14
Islander
at this point every 12000 miles would be four months
Kingfisher24
WBCCI 2541
4CU
Wheel bearing repacking dlb435 Wheels, Hubs & Bearings 21 08-17-2014 08:34 AM
How do I get this off? (re: repacking bearings) Zstream Wheels, Hubs & Bearings 7 05-04-2008 08:58 AM
1st time repacking my wheel bearings Bill C. Axles 9 02-22-2008 07:49 PM
Repacking Wheel Bearings Buttercup Axles 38 05-07-2005 08:57 PM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
