03-11-2012, 08:09 PM
#21
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Ray,
Hairy palms are mitigated by latex.
I have those sealed gear oil filled bearings, (different brand?), on our small boat trailer, they work at keeping the water out and have lasted 8 yrs, most likely because of the light weight. I can see them failing on a heavy trailer with the higher bearing temps over long distance. Not something I'd want on the AS.
04-01-2012, 04:10 PM
#22
2009 23' FB Flying Cloud
Hot Springs Village
, Arkansas
Had mine repacked after it was in storage for about 8 months. We just finished a 3,000 mile trip to Florida & return. My question: How often should the bearings be repacked & how many miles between having them serviced? We are planning a trip out "West" in a few weeks. I have had bearings go out on both a utility & boat trailer. Not good when you have to unhook & leave it on the side of the road. I haven't taken the wheels & hubs off to see how they are set up on the Airstream since we have only had it little over a year. My boat trailer has a grease fitting & it's east to squirt a little with a grease gun. So do "Buddy Bearing Grease Fittings" work on Airstreams?
04-01-2012, 04:33 PM
#23
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Sams,
I also have the BB's on a boat trailer, they work very well at keeping the water out and bearings lubed. I don't feel they would be that effective on the AS what with the much heavier loads and higher temps involved. The grease as it thins with heat is much more likely to be forced out the rear seal by the pressure spring.
At 3000mi your re-pack should be fine, but I would still remove the drums and inspect the brakes and bearings just to be on the safe side.
Check out this thread to see what to check for on the brakes and bearing condition.
04-01-2012, 05:40 PM
#24
Master of Universe
2008 25' Safari FB SE
Grand Junction
I believe Airstream recommends 6 months or 10,000 miles, whichever comes first. I have gone 18,000 miles and many more months before I repacked them and they were fine. It is good to have spares—one of each size bearing, seals and grease ready for an emergency. It is not easy to find out the proper sizes when stuck in Boondockville where cellphones don't work.
Gene
04-01-2012, 06:01 PM
#25
1965 22' Safari
East Islip
, New York
I'm also going to say you just can't beat the old palm packing method. It's quick, easy, effective and has the least amount of waste.
Though I usually throw them in the parts washer first to get all the old grease and crud out of them. Can do it with a bucket and a spraycan of break cleaner. Can't give them a proper inspection unless you can actually see the cage and rollers.
-Hans
04-01-2012, 06:42 PM
#26
Pittsfield
, Maine
After repacking bearings for the past 55 years or so by hand, I decided to try the packer first mentioned above. It was a bit pricey at $29.00, however, I think that it did a very good job. I did not use the grease zerk on the top - choosing instead to simply pre-fill the container with wheel bearing grease. It takes quite a bit of pressure (---slowly) to push the grease through the bearing but, the ability to see a curl of old grease come out of the top of the bearing at each roller, followed by new grease, was proof-positive that the bearing was indeed packed. I don't believe that the amount of waste, or surplus, grease was any worse than when packing by hand. For me, it was a time-saver, and not near as messy as hand packing.
Cracker
04-01-2012, 07:08 PM
#27
1999 34' Excella
Joshua
This is the one I use and it works great...
Lisle Corporation
History doesn't repeat itself, people do!
04-02-2012, 04:57 AM
#28
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
"I'm also going to say you just can't beat the old palm packing method. It's quick, easy, effective and has the least amount of waste."
I'm with Hans, although I changed my procedure substantially this time.....I used a glove.
04-02-2012, 08:47 AM
#29
Master of Universe
Grand Junction
Grease is cheap. A packer does the job a lot faster and time, even for a retiree, does matter.
Gene
04-02-2012, 10:05 AM
#30
Pittsfield
, Maine
Bob:
Before you take off on a trip I just wanted to point out that, according to the container in the picture, you inadvertantly packed the bearings with raspberry yogurt!!! I would strongly advise repacking with grease!!!
Cracker
04-02-2012, 10:16 AM
#31
Moderator dude
1966 26' Overlander
Phoenix
Originally Posted by Cracker
Bob:
May be not ..... it does have 3% milkfat!
>>>>>>Action
06-22-2012, 03:54 PM
#32
2015 23' FB Flying Cloud
2003 25' Safari
Forestville
Is there a recommended brand of grease for these bearings?
06-22-2012, 03:59 PM
#33
Silver Mist
Riverhead
, New York
Not really, I like the silicon,
also put the grease in a sandwich bag, work it in take out put in place hands are clean.
06-22-2012, 04:07 PM
#34
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
I use Lucas Oil x-tra Heavy Duty Grease. Do not really have a reason, it is just good grease.
Annette
06-22-2012, 04:09 PM
#35
2003 25' Safari
Forestville
Appreciate the information.
06-22-2012, 05:25 PM
#36
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
PENZ RED...
07-19-2012, 07:21 PM
#37
2003 25' Safari
Forestville
I highly recommend the Lisle bearing packer for the job. I used Lucas Oil Red & Tacky #2 as this is the grease the local shop uses for their wheel bearing repacks on all vehicles.
I also used a dial indicator to confirm my endplay. AS specs in my manual are 0.001 to 0.010 and my range is 0.005 to 0.007. This amounted to backing the nut off two notches from seating the bearings.
The rocket scientist that did the job previously had them way too tight and liquified the grease. Luckily, the bearings were still in good shape.
Bob, Julie & Cali
06-08-2013, 06:17 PM
#38
Cheyenne
, Wyoming
To everyone who contributed to info about repacking wheel bearings.
thanks so much for the input. Very helpful.
WyoAir
