Old 03-11-2012, 05:17 PM   #15
r carl's Avatar
Lin , Ne
Originally Posted by Mexray View Post
I'm retracting my recommended 'suggestion' in post #6 above - the: Bearing Grease Packer - Save on this Bearing Grease Packer
I tackled the packing of our wheel bearings yesterday - tried using the contraption above - it's a BIG piece of CRAP!!! It's now a candidate for landfill!
You unscrew the top, place the bearing inside, replace the top and begin pumping grease into the unit via the Zerk on top...then you pump some more...then you pump some more - almost a complete cartridge to fill that mother up...Then you unscrew the top and there the bearing is, in the middle of a 'tub' of grease...by the time you get the bearing out of that 'blob', you've got both hands covered in grease!
After that first 'experience', I quickly went back to packing the bearings with the 'palm' method, which I've done all my life - effective, quick, and no wasted grease! - Long live the 'Palm' method...
BTW, the bearing repacking was brought about by the failure of two of the Kodiac oil-bath seals that I had put on the new axles when I installed em'...What a mess - had to replace three pairs of brake shoes - the two that were covered in oir, and the third that was almost worn out due to doing most of the braking the others weren't providing!
What a mess, cleaning up the two brakes/hubs that were covered in rear-axle-like smelly oil - yeah the bearings were like new, well lubed, and everything else was also like new, 'preserved' in oil!
Live and learn...The basic old grease packed wheel bearing technologies are best left alone!
Thats what happends when you buy a china copy of this.
Sears: Online department store featuring appliances, tools, fitness equipment and more
Old 03-11-2012, 05:32 PM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
"Thats what happends when you buy a china copy of this."
No tanks....KISS
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-11-2012, 05:44 PM   #17
JimGolden's Avatar
1977 31' Excella 500
I do it the OLD SCHOOL way. Get six new seals at NAPA before the job, then do it. It sux, but it works. I guess I could use the latex....but the old school way works fine.
Lotsa luck!
- Jim
JimGolden is offline   Reply With Quote
Old 03-11-2012, 05:47 PM   #18
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I figured out how to do it without getting all greasy. I get either o ne of my sons to do it. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-11-2012, 06:30 PM   #19
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I always do a repack just by packing the grease into the races by hand - no big deal.
I think that putting a whole cartridge full of grease into one hub as someone mentioned could be inviting problems. No need for that much grease.
I don't speak from experience in that regard but I have heard that too much grease can cause the grease to overheat, fluidize (if that is a word) and runout past the grease seals.
Possible for someone doing this for the first time, the biggest challenge might be getting the new grease seals back in place properly.
Most sources recommend installing new seals each time and I generally do that. Getting them in properly is just a matter of gently tapping them in squarely with a hammer and a suitable block of wood - all pretty easy.
Once re-assembled tighten the nut hand gently with a large crescent wrench, then back off one flat on the nut so you can get the cotter pin in place and you are good to go!
You'll possibly save up to $200 and know it is done properly!
You can find many websites that will give more detail and give you confidence if it is your first attempt.
Incidentally, if you have two axles on your trailer, then rather than mess with jacks, just run one wheel up onto those stacking blocks, assembled in a pyramid, and the adjacent wheel will be hanging in the air ready to remove! I would suggest breaking the lugnuts slightly loose first - easier than when the wheel is spinning free in mid air!
Brian (Currently in melbourne Fla!)
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 03-11-2012, 07:22 PM   #20
Mexray's Avatar
1978 28' Ambassador
Morada , California
Robert,
I'd say, before packing wheel bearings with the 'Palm Method', if one had any hair in their palm, it would be prudent to shave first lest some get caught in the rollers...
Ray & Pat; Morada, CA
Old 03-11-2012, 08:09 PM   #21
Ray,
Hairy palms are mitigated by latex.
I have those sealed gear oil filled bearings, (different brand?), on our small boat trailer, they work at keeping the water out and have lasted 8 yrs, most likely because of the light weight. I can see them failing on a heavy trailer with the higher bearing temps over long distance. Not something I'd want on the AS.
PFC
"Tahawus"
RLC
John Prine
Old 04-01-2012, 04:10 PM   #22
sams's Avatar
2009 23' FB Flying Cloud
Hot Springs Village , Arkansas
Had mine repacked after it was in storage for about 8 months. We just finished a 3,000 mile trip to Florida & return. My question: How often should the bearings be repacked & how many miles between having them serviced? We are planning a trip out "West" in a few weeks. I have had bearings go out on both a utility & boat trailer. Not good when you have to unhook & leave it on the side of the road. I haven't taken the wheels & hubs off to see how they are set up on the Airstream since we have only had it little over a year. My boat trailer has a grease fitting & it's east to squirt a little with a grease gun. So do "Buddy Bearing Grease Fittings" work on Airstreams?
sams is offline   Reply With Quote
Old 04-01-2012, 04:33 PM   #23
Sams,
I also have the BB's on a boat trailer, they work very well at keeping the water out and bearings lubed. I don't feel they would be that effective on the AS what with the much heavier loads and higher temps involved. The grease as it thins with heat is much more likely to be forced out the rear seal by the pressure spring.
At 3000mi your re-pack should be fine, but I would still remove the drums and inspect the brakes and bearings just to be on the safe side.
Check out this thread to see what to check for on the brakes and bearing condition.
PFC
"Tahawus"
RLC
John Prine
Old 04-01-2012, 05:40 PM   #24
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I believe Airstream recommends 6 months or 10,000 miles, whichever comes first. I have gone 18,000 miles and many more months before I repacked them and they were fine. It is good to have spares—one of each size bearing, seals and grease ready for an emergency. It is not easy to find out the proper sizes when stuck in Boondockville where cellphones don't work.
Gene
Old 04-01-2012, 06:01 PM   #25
1965 22' Safari
East Islip , New York
I'm also going to say you just can't beat the old palm packing method. It's quick, easy, effective and has the least amount of waste.
Though I usually throw them in the parts washer first to get all the old grease and crud out of them. Can do it with a bucket and a spraycan of break cleaner. Can't give them a proper inspection unless you can actually see the cage and rollers.
-Hans
HHaase is offline   Reply With Quote
Old 04-01-2012, 06:42 PM   #26
Cracker's Avatar
Pittsfield , Maine
After repacking bearings for the past 55 years or so by hand, I decided to try the packer first mentioned above. It was a bit pricey at $29.00, however, I think that it did a very good job. I did not use the grease zerk on the top - choosing instead to simply pre-fill the container with wheel bearing grease. It takes quite a bit of pressure (---slowly) to push the grease through the bearing but, the ability to see a curl of old grease come out of the top of the bearing at each roller, followed by new grease, was proof-positive that the bearing was indeed packed. I don't believe that the amount of waste, or surplus, grease was any worse than when packing by hand. For me, it was a time-saver, and not near as messy as hand packing.
Cracker
Cracker is offline   Reply With Quote
Old 04-01-2012, 07:08 PM   #27
Dwight's Avatar
1999 34' Excella
Joshua , Texas
This is the one I use and it works great...
Lisle Corporation
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 04-02-2012, 04:57 AM   #28
"I'm also going to say you just can't beat the old palm packing method. It's quick, easy, effective and has the least amount of waste."
I'm with Hans, although I changed my procedure substantially this time.....I used a glove.
PFC
"Tahawus"
RLC
John Prine
cincinnati, service shops, wheel bearings
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Sealed Wheel Bearings greatlakes Wheels, Hubs & Bearings 7 12-05-2011 06:50 AM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
Wheel Bearing Help Needed mile2885 Wheels, Hubs & Bearings 31 06-16-2011 10:22 AM
Seals For Wheel Bearings ~ 1958 Pacer Ariz-Pacer Wheels, Hubs & Bearings 9 03-22-2011 10:50 PM
