Old 10-11-2018, 04:59 AM   #1
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
Removing or tightening lug nuts - wrench alignment
Posted this earlier, but got 0 responses. With my 345 LE moho dually wheel nuts, any suggestions on keeping the deep socket (with extension) parallel with the stud while applying manual pressure to remove the lug nuts?
Had too many bad experiences when the socket failed to maintain the 90° necessary to avoid rounding the nut. Yes, I know if I had the air tool used to install the nuts, this wouldn't be a problem.
wimpy is online now   Reply With Quote
Old 10-11-2018, 06:36 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
You can purchase an electric impact gun from most manufacturers like Milwaukee, Bosch, Makita etc.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 10-11-2018, 09:06 AM   #3
Mollysdad's Avatar
I add an extension to the breaker bar. That moves the pivot slightly further out from the rim.
Also, newer sockets have a rounded flat, if that makes any sense so they don't just grab on the corners, thus reducing rounding off the nut.
There's still no substitute for holding one hand on the fulcrum point, no matter how long the "persuader".
Old 10-11-2018, 02:01 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
How long is the extension?, what size the nut?
My "old school" is difficult to get off center.
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 10-12-2018, 11:03 AM   #5
1985 31' Excella
st. Paul , mn
I've done semi-trucks , heavy equipment etc.
Even had to use 10' - 20' cheater-pipe to crack loose .
The trick is to use a jackstand to hold the extension at the same hight as the nut / bolt your working .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 10-12-2018, 12:11 PM   #6
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
We have A BINGO.
But fear not if you don’t have a jack stand cause if you are driving a pickup pull out that worthless looking tire jack that came with it and see it will rescue you.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
McGard Lug Nuts @ Lock nuts PSU1981 Wheels, Hubs & Bearings 0 10-10-2018 12:37 PM
Wrench for lug nuts Dingo Girl Wheels, Hubs & Bearings 0 11-30-2016 04:32 PM
Lug Nuts on a new Airstream & Tightening J5MM 2011 - 2015 International 15 05-30-2016 06:30 PM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
