Old 06-13-2010, 07:58 PM   #85
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
You can use a dowel or other piece of wood to punch out the seal. This is less likely to damage it. Constantly hitting the dowel with a rubber mallet while rotating the dowel around the seal works best.
Gene
Gene is online now   Reply With Quote
Old 06-13-2010, 08:14 PM   #86
tpi
Trabuco Canyon , California
Probably what I missed is moving the bearing as far away from the seal as possible. I let the bearing fall on the seal which didn't allow anything to get around it to knock out the seal.
tpi is offline   Reply With Quote
Old 06-14-2010, 06:24 AM   #87
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Tough to beat this tool for less than $10
Here is what I use from Sears or any auto parts store for pulling the seals:
Amazon.com: Seal Puller: Automotive
SilverCottage is offline   Reply With Quote
Wheel bearings Allen H Axles 18 10-31-2007 04:12 PM
Wheel bearings FlyingW Axles 3 07-01-2006 05:36 PM
Airstream Wheel Bearings Hunter_1 Member Introductions 15 04-18-2006 02:54 PM
Wheel Bearings 76ArgosyDave Axles 7 06-29-2005 03:00 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
