Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels, Hubs & Bearings
Old 06-13-2010, 02:55 PM   #81
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by tpi View Post
Does anyone use a puller tool with them? I pulled them apart with vice grips and dug them out with screwdriver. Do not attempt to drive them out with the bearing, you'll wreck the bearing. Ask me how I know
Use a socket on the end of an extension. I use a 3/4" socket (or so) and install it on a 9" 3/8 drive extension. The socket is inverted on the extnsion. Then I tap on the other end of the sxtension to drive out the seal. The other method I have used is a very long punch into the seal. However some one has decided that particular punch was something they needed more than me.
>>>>>>>>>>>>>>>>Action
Old 06-13-2010, 03:01 PM   #82
tpi
Trabuco Canyon , California
So you pass the socket thru the bearing and apply the force directly to the seal? Thanks for the tip..
tpi is offline   Reply With Quote
Old 06-13-2010, 06:16 PM   #83
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Yes, with the hub off the vehicle and the outer bearing removed, use a socket that is smaller than the inside of the innner bearing. Drop the socket on a long extension (like 9") through the hub from the outer side. MAKE SURE it lands on the seal. To do this you may have to push the bearing up into the hub. Tap lightly on the other end of the extension. Recommend using 3/8 drive socket and extension.
It can also be done with the extension only which will always damage the seal. I have used the socket when I was out in the boonies and had to save the seal because I did not have a spare.
Just be careful not to tap on the innner bearing cage. It isn't that strong.
>>>>>>>>>>>>>>Action
Old 06-13-2010, 07:35 PM   #84
tpi
Yes I found this out the hard way, and at least my seals were very tough to punch out.
Appreciate your help. Should make this much easier in the future.
Old 06-13-2010, 07:58 PM   #85
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
You can use a dowel or other piece of wood to punch out the seal. This is less likely to damage it. Constantly hitting the dowel with a rubber mallet while rotating the dowel around the seal works best.
Gene
Old 06-13-2010, 08:14 PM   #86
tpi
Probably what I missed is moving the bearing as far away from the seal as possible. I let the bearing fall on the seal which didn't allow anything to get around it to knock out the seal.
Old 06-14-2010, 06:24 AM   #87
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Tough to beat this tool for less than $10
Here is what I use from Sears or any auto parts store for pulling the seals:
Amazon.com: Seal Puller: Automotive
SilverCottage is offline   Reply With Quote
Wheel bearings Allen H Axles 18 10-31-2007 04:12 PM
Wheel bearings FlyingW Axles 3 07-01-2006 05:36 PM
Airstream Wheel Bearings Hunter_1 Member Introductions 15 04-18-2006 02:54 PM
Wheel Bearings dpligocki Axles 7 06-29-2005 03:00 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
