Old 02-12-2013, 08:21 AM   #15
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by ddruker View Post
I wonder if you can trademark designs. I thing I'm going to try out a set of the T05s and see how they look.
It seems like certainly something should to be able to be done. I'm basing this on observation of recent court decisions in the electronics field. These decisions have shown that even vague ideas of how software should preform a particular function are apparently eligible for patents.
I like this version of the T05
Ken
Old 02-12-2013, 07:25 PM   #16
ddruker's Avatar
2000 27' Safari
Palo Alto , California
Thanks Ken. I was thinking about the plain aluminum finish thinking that would go well with my trailer, and I like the machined insert as compared to standard stainless or chrome caps. Can you share why you prefer the wheel with the black highlights better?
- Dan
1999 27' Safari + 2011 Mercedes GL 350 Turbo-diesel
ddruker is offline   Reply With Quote
Old 02-12-2013, 07:44 PM   #17
Ag&Au's Avatar
Now that I see these I don't prefer the black. These would look a lot better on an Airstream. I'll make you a deal, you order these and I will trade you my now nearly priceless no longer available T-03s.
You are correct the inserts look much better.
Ken
Old 03-01-2013, 09:51 AM   #18
ddruker's Avatar
2000 27' Safari
Hi Ken,
I did order them - Sendel T05-66655SM - just arrived last night and I'm hoping to put them on this weekend.
Here's what they look like in the box and with the cap installed.
- Dan
Old 03-03-2013, 10:48 AM   #19
ddruker's Avatar
2000 27' Safari
Here is what the Sendel T05's look like on the trailer...
- Dan
Old 03-06-2013, 01:25 PM   #20
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
Question for the boss,
I noticed corrosion on my new, yet to be officially delivered EB wheels? Was there ever any clear coat on the machined polished sections? This unit was built in Dec/Jan and delivered to the west coast before 1/21/13. I picked at it with my fingernail and it didn't seem to be a thin surface issue like surface rust on chrome, but deeper. How to fix, would buffing have a chance?
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 03-11-2013, 12:16 PM   #21
ddruker's Avatar
2000 27' Safari
Hi CDONA,
Below is the answer to your question from Rick at Sendel. It sounds like he's not sure if Airstream is using real Sendel T03 wheels or one of the Chinese copies. You (or anyone else with factory Eddie Bauer wheels) should be able to tell for sure by removing one of the wheels and looking at the backside - it should have the manufacturer information stamped into the casting.
My Sendel T03’s have been copied by several factories and I can’t 100% tell you whether these are ours or not. My suggestion to the owner is to go back to Airstream for help. The big issue is that some makers are using aluminum wheels with steel center caps and lugs. These dissimilar metals cause corrosion even before delivery based on how long the unit sits and what it’s exposed to.
- Dan
Old 03-12-2013, 08:23 AM   #22
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Hi CDONA,
My Sendel T03ís have been copied by several factories and I canít 100% tell you whether these are ours or not. My suggestion to the owner is to go back to Airstream for help. The big issue is that some makers are using aluminum wheels with steel center caps and lugs. These dissimilar metals cause corrosion even before delivery based on how long the unit sits and what itís exposed to.
Don't the Sendel's use a steel insert for the lug nut penetration and seat? Does this cause the same problem relative to corrosion?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 03-12-2013, 08:42 AM   #23
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Hi CDONA,
I can't make sense of this reply. My new Sendels came shipped with the center caps in separate packaging than the wheels, they were not on the wheels. Lug nuts were not included, would he be suggesting stainless steel lug nuts, certainly not aluminum.
doug k
Old 03-12-2013, 12:08 PM   #24
CDONA's Avatar
I went back to the dealer & look at my rig yesterday (with camera), the corrosion mostly gone, but a small trace in the gap around the chrome center cap and lugs. A week ago it looked like there were rubber gaskets around the lug nuts, (gotta wear my readers). We were doing my final walk thru when I found the crud with the instructor/tech right there.
Do they balance the wheels?
Old 03-12-2013, 07:16 PM   #25
ddruker's Avatar
2000 27' Safari
Here are rick's comments to doug and alphonse - the original questions are in italic font. I think I need to get Rick a login here...
We do not use steel inserts in the pilot holes (lug holes) Both Honda and GM have gotten away from this for the same reason we did. Years ago the purists thought it be better for a steel lug nuts to retain torque if it fit into a metal lug insert. With 6 million wheels in the field without inserts and not a single failure we found it also not necessary. Besides, the steel insert, steel lug studs with steel lugs would cause greater corrosion issues as most of the corrosion comes from the back of the wheel thru the center bore or pilot holes. Accelerating the decay.
I can't make sense of this reply. My new Sendels came shipped with the center caps in separate packaging than the wheels, they were not on the wheels. Lug nuts were not included, would he be suggesting stainless steel lug nuts, certainly not aluminum. The only Sendel wheels that are shipped with caps are the T05ís. All other wheels are shipped without caps and supplied by the facilitator or end seller. Most are steel or stainless which still are dissimilar metals. Most stainless lugs are just metal lugs with a stainless cover. The base is still steel and will cause corrosion.
Dan comments - I did some quick research on galvanic reactions - it looks like that generally speaking Stainless Steel is going to react less with Aluminum than regular carbon steel is - so you would be better off with solid stainless lug nuts and a stainless cap as opposed to chromed steel lug nuts and cap. Or do what I did - get the T05 rims which come with a matching cap and hide the lug nuts so you don't have to worry about surface corrosion at all...
- Dan
Old 03-12-2013, 07:36 PM   #26
Alphonse's Avatar
Lower Alabama , USA
Dan
Wouldn't chrome be far less prone to cause galvanic corrosion than stainless?
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 03-12-2013, 10:13 PM   #27
ddruker's Avatar
2000 27' Safari
Note I said quick research...
- Dan
Old 03-12-2013, 10:26 PM   #28
mefly2's Avatar
2015 25' FB Eddie Bauer
Dan - great look on two sets of nice wheels.
Sedona- ours have some surface corrosion, too; likely from the salt air in Seattle.
