Old 06-21-2007, 06:32 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
"IF" that trailer will ever be towed on a public road, then make sure the wheels are rated at 2600 pounds each.
Question, I can understand you need 2600lb wheels if the TT weights 10,000lbs.
But if the TT weighted 7,000lbs would 1750lbs wheels be enough, something like the load cap on the tires?
'77 Sovereign Intl 31' CB
Old 06-21-2007, 08:30 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I agree 100% with Andy.
The 2600lb load rating is important because if a tire blows, the healthy wheel will have to support that side of the trailer.
Airstreams approaching 10000lbs usually have three axles, I believe.
Load range C tires have a LR of 2150lbs, while D-Rated tires can carry 2450lbs, btw.
Only 14" Marathons are rated down to 1760lbs. Rarely used on Airstreams.
I bought and love these wheels:
Aluminum Trailer Wheel Style: SERIES #03 Size: 15 x 6 Bolt Pattern: 6 x 5.5 Bore Size: 4.25 Load Rating: 2830 lbs @ 80 PSI Offset: 0mm
Uwe
www.area63productions.com
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Front wheel drive ?? ALANSD Airstream Motorhome Forums 14 08-25-2002 12:47 PM
'71 Airstream Caravel 18' weight specs PeterH-Airstreamer 1969-1971 Caravel 0 06-15-2002 06:28 AM
