Old 01-21-2011, 10:55 AM   #1
blickcd's Avatar
Milford , Ohio
Putting modern wheels on a '79
I'm about due for another set of tires and would like to replace my old, possibly original steel wheels and mis-matched hub caps, with aluminum wheels as are put on the new Airstream trailers.
A year or two ago I put a new set of GKN axles on my trailer which use lug nuts as opposed to lug bolts, and I know I need to get the pretty closed end nuts so all will look nice.
Question is, what tire size do the new trailers put on these aluminum wheels? I assume the bolt pattern will match up with my axles but is there anything different regarding wheel well clearance or axle spacing that makes putting the new wheels and OEM tires on a problem?
Christopher
blickcd is offline   Reply With Quote
Old 01-21-2011, 11:16 AM   #2
1986 25' Sovereign
Plant City , Florida
Christopher
Chris,
I don't think you will have any issues as long as you stick with OE. I know that you will have to choose between 15" and 16" wheels. I think you would be better off with 16"
I just bought new tires and wheels from here. Tredit Tire - Tires and Wheels for RVs and Trailers
I got 4 wheels for 380ish.
ck21084 is offline   Reply With Quote
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 07:41 PM
2 wheels or 4 WRDinAZ Towing, Tow Vehicles & Hitches 17 01-11-2011 07:14 PM
Question about bolting in Dexter axles fitzjo1 Axles 22 12-31-2010 06:54 PM
