Old 05-17-2014, 09:42 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Pulling the hubs and bearings on a Nev-r-lube axle
Well, following Andy Rogozinski's advice I pulled the hubs and drums today for a brake inspection.
The brakes were fine but I did find a shock absorber that was broken in half.
But the main lesson here is that it takes far more tools to work on these than on the older hubs with tapered bearings. You have to have a set of external snap ring pliers, and a 1 7/16" socket wrench. A great deal of torque was required, on my trailer, to get the spindle nut off, more than the 150 ft-lb torque specification. Whether this is because it was overtorqued at the factory or for some other reason I do not know.
I believe I would have broken a 1/2" breaker bar had I used one. Fortunately, I have a set of 3/4" drive wrenches left over from the days when I worked on agricultural equipment.
Photos so you know what to expect if you try this...
Name:	IMG_20140517_130749_351 (800x451).jpg
ID:	212146   Click image for larger version
Name:	IMG_20140517_130801_746 (800x451).jpg
Name:	IMG_20140517_130918_567 (800x451).jpg
ID:	212148   Click image for larger version
Name:	IMG_20140517_131243_111 (800x451).jpg
Name:	IMG_20140517_131843_792 (800x451).jpg
ID:	212150   Click image for larger version
Name:	IMG_20140517_132152_530 (800x451).jpg
Name:	IMG_20140517_132207_844 (800x451).jpg
Old 05-18-2014, 11:02 AM   #2
2010 27' FB Classic
N/A , Texas
Thanks for posting this thread.
This is on my "to do" list.
Old 05-18-2014, 11:57 AM   #3
Excellent reasons as to "WHY" not to use "never lubes".
And by the way, no one stocks parts for those axles.
If you need any parts, they all have to be special ordered.
Plan on several days delay, if you need one of those parts while on a trip.
Never lubes are fine, for farm equipment, so that if you have a break down, your still at home.
Old 05-20-2014, 11:37 AM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Jammer,
How many miles on the rig would you guess?
>>>>>>>>>Action
Old 05-20-2014, 11:41 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Probably around 5,000, but my travels tend to take me through the Minneapolis metro area, and also on 2-lane roads, so the brakes have a hard life.
Old 05-20-2014, 11:45 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
They look pretty good in the pics however 5000 miles seems hardly much of a work out.
I get the reason to inspect them, too bad there isn't some kind of inspection slot(s) in the backing plate for that purpose. This would elinimate tearing down the hubs. Or I suppose these hubs with disc brakes would be an awesome combo.
>>>>>>>>>>>>>Action
Old 05-20-2014, 01:36 PM   #7
1981 31' Excella II
New Market , Alabama
I assume it is a sealed cartridge bearing of some sort? Something like what you would use on the front of a front wheel drive car?
Perry
Old 05-20-2014, 01:50 PM   #8
r carl's Avatar
Lin , Ne
Perry
Yes, they are sealed bearings.
Old 05-20-2014, 08:31 PM   #9
KYAirstream's Avatar
Northeastern , Kentucky
Just curious, what parts would be needed that would likely be hard to get?
KYAirstream is offline   Reply With Quote
Old 05-20-2014, 08:48 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
There are a couple of problems service-wise. But to keep this in context, from everything I've been able to find, these bearings rarely fail unless they're submerged under water, subjected to overtorquing at the time of installation, or after lengthy extended use (approaching 100,000 miles or more).
The first problem is that because the bearings are expensive, not used on very many trailers, and rarely fail, few places stock them.
The second problem is that installing a bearing in an existing drum requires a hydraulic press. It is possible, though expensive, to purchase drums with the bearings already installed.
Finally, for the reports of failures I have been able to find, there is a high incidence of the spindle being damaged to the point where it must be replaced.
Old 05-20-2014, 08:52 PM   #11
Roughly how expensive is the drum with bearing? However, I suppose a spare on hand doesn't do much good if the spindle is damaged. What's involved with the replacement of the spindle?
centramatics and nev-R-lube bearings gtc6452 Wheels, Hubs & Bearings 14 08-09-2013 09:59 AM
Nev-R-Lube Axle/Centramatics Al - K4GLU General Repair Forum 31 03-31-2013 05:26 PM
NEV-R Lube Hubs stefario General Repair Forum 1 05-15-2012 07:07 PM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
