Old 05-19-2005, 03:07 PM   #1
Proper wheels--trailer vs. regular
I've searched the various fora trying to find info on this question, and haven't come up with anything, so I'm trying a new post.
I have a '66 Caravel. I'm trying to replace the wheels and tires. One wheel may or may not be original (it's rusty enough). It's a 15" with 5 lugs, 4.5" lug circle, 2 5/8" opening. I'm told by wheel dealers that it is a trailer wheel.
The other wheel is an ugly white "spoked" modern looking thing. I don't believe it is a trailer wheel. I say this because the tire on the other one clears the shock absorber by about an inch, and this one clears it by at least two inches. I' like to replace this one, and use it as the spare.
Hence my question. The dealers are saying I need a trailer wheel, primarily to insure clearance with all the stuff under the trailer. But, if the non-trailer wheel has adequate clearance, what's the difference?
I've seen only a few posts in which folks have said we should definitely use trailer wheels. But, perhaps because I'm in Appalachian Ohio, nobody seems to have them in the size I need.
So, my question is, is it necessary to use a trailer wheel? What have been the experiences of you folks?
Jack
armycot is offline   Reply With Quote
Old 05-19-2005, 03:20 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Jack,
I have seen posts that indicate trailer wheels have a higher load rating than regular automobile wheels. Member Sneakinup posted a final result, but I can't find the thread.
From personal experience in another matter, I know that my '67 Airstream wheels have an offset to them. You can read about it here. Special thanks to markdoane for his insight.
Tom
Old 05-19-2005, 04:06 PM   #3
armycot.
The correct wheel for your Caravel is 15 inch with 5 holes on a 4 1/2 bolt circle. It should also have a minimum weight rating of 1750 pounds.
In your case the wheel can be any where from a zero to 1/2 inch offset.
Old 05-19-2005, 04:28 PM   #4
Somewhere , Indiana
Red face Help!
Armycot,
You may find some helpful hints in the:
Axle, Brakes, Wheel & Tire Forum
Several threads that have your topic covered are: “New Rims” & “Need help with wheel upgrade”
These are simply the first ones that I cam across, several more can be found if you dig.
Happy Hunting ,
Henry
axleman is offline   Reply With Quote
Old 05-19-2005, 04:30 PM   #5
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Speaking of wheels - and changing them - where does the balancing come in?
Do you balance each tire and then how do you balance them on the trailer if there is such a thing? And who would best do that balancing?
thanks for any info
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 05-19-2005, 04:37 PM   #6
Originally Posted by axleman
Armycot,
Happy Hunting ,
Henry
Henry,
How do you get by with all that special text formatting?
I made one post by accident with more than ASCII characters, and the Font Police promptly sent me a PM asking me to refrain from special fonts & sizes.
Jedi mind trick?
joatmon is offline   Reply With Quote
Old 05-19-2005, 04:44 PM   #7
Somewhere , Indiana
Question Oop's
Originally Posted by joatmon
Henry,
Jedi mind trick?
Joatmon,
Do you want the truth? By accident man, I guess that I had the bold set! I hope the font police go easy on me as it was an accident.
Regards,
Henry
PS: What is this Jedi mind trick you speak of?
Old 05-19-2005, 04:47 PM   #8
Images: 59
GT6921,
There are at least four different methods:
1. Do nothing
2. Balance the wheel and tire
3. Balance the hub, and the wheel & tire
4. Use Centrimatics, or ceramic beads.
Here is the best thread on balancing: http://www.airforums.com/forum...ead.php?t=9153
Old 05-20-2005, 06:02 AM   #9
How about rim width???
Hey, guys, thanks for the responses.
So, after spending more time than I should have on Google, I've finally found somebody who sells OEM steel rims for trailers in the size I need (lowcosttrailersupplies.com).
Now I need to know if I should use a 15x5 or 15x6 rim. I suppose this ties into related questions about tires and fit into the wheel well. Perhaps Andy would be willing to weigh in on this, as well as others.
Jack
Old 05-20-2005, 06:48 AM   #10
Buckhorn , Ontario
Images: 59
Originally Posted by markdoane
GT6921,
1. Do nothing
Thanks Mark - I will print off some good info there for the Hubster.
For our up coming trips.
Old 05-20-2005, 07:22 AM   #11
Joatmon,
Regards,
Henry
Just remember, I am the self-proclaimed Axle Jedi! Henry is not my father!
Anon is offline   Reply With Quote
Old 05-20-2005, 11:32 AM   #12
armycot
Use the 15 x 6 wheels.
They will allow the tire to contain more volume of air, a good thing, as that will give the trailer a softer ride.
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Lookin for answers-picking up newly acquired trailer COArgosy78 Our Community 2 09-02-2002 01:23 PM
Trailer Travel, a visual history of mobile America 83Excella Our Community 6 08-20-2002 07:13 AM
New trailer, old club rally Pahaska Other Rallies & Events 7 07-24-2002 01:26 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
