Old 11-29-2007, 10:02 AM   #1
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Question Pressure Pro on 2007 Safaris ?
After reading the numerous posts on tire problems I've decided to purchase the Pressure Pro tire pressure monitoring system. I checked out the cast aluminum wheels (picture attached) on my 2007 25' Safari and it appears that there is very little room to mount the Pressure Pro sensors. Has anyone with a 2007 Safari installed the Pressure Pro system on your trailer and how did you mount the sensors?
Name:	Airstream Wheel 2007.jpg
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 11-29-2007, 10:30 AM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I too am getting the PressurePro tire monitoring system from Santa (I've been a good boy ) but don't have the problem with my rims that you have.
A solution for your application are valve stems made at an angle. I have seen them on trucks and they are available on line. Still, it looks like you can get the sensor on you stem. Do you have one to try on or are you asking before you purchase to be sure?
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 11-29-2007, 11:05 AM   #3
westernviews's Avatar
2013 27' Flying Cloud
Livingston , Texas
I have the PressurePro monitoring device on my tires. No problem. Unfortunately, the last flat I had unplugged it to use my GPS system. Bad decision. Thank goodness for good samaritans who honked and pointed to the tire.
Westernviews.us
westernviews is offline   Reply With Quote
Old 11-29-2007, 11:09 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Sounds like you need one of these...
Richard
Old 11-29-2007, 11:26 AM   #5
2dabeach's Avatar
Westerviews
Does your 2007 27' have the same wheels as my 25'?
Old 11-29-2007, 02:44 PM   #6
Livingston , Texas
I think they are the same: aluminum wheels ST 225-75 R15.
Westernviews.us
Old 11-29-2007, 03:28 PM   #7
2003 25' Safari
Eden Prairie , Minnesota
And you have the dreaded filiform corrosion starting on your 2007's wheels...
Dan
dmac is offline   Reply With Quote
Old 11-29-2007, 04:32 PM   #8
2dabeach's Avatar
Dan
Thanks for pointing that out. Is there anything that I can do to fix it?
Old 11-29-2007, 05:43 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
2dabeach...glad to see this question asked about the Pressure Pros, as we are considering them...and we have the same wheels.... thanks!
And there are many discussions of corrosion/filiform on the forum...try a search fpr corrosion or filiform and you will get lots of discussion to review.
TB
TB & Greg and Abbey Schnauzer
#3954
Old 11-29-2007, 08:18 PM   #10
2dabeach's Avatar
TBRICH....Thanks for the information on the corrosion posts. The Pressure Pro dealer is sending me his demo sensor that I can try to mount on the wheel. As Pressure Pro seems to prefer metal valve stems, I'm going to check with a local tire shop and see if I can get metal valve stems with a bend that will allow the installation of the sensors. Will update as I get additional information.
Old 11-29-2007, 08:37 PM   #11
New Borockton , Alabama
Images: 21
We are loading Santa's sleigh as we speak and it's getting pretty full. They are the best product of the decade. We're not allowed to advertise anything other than MSRP but a call never hurts. I need an emote with my arms crossed, finger on chin and whistling.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 11-30-2007, 10:09 PM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
2dabeach...let me know if the angled valve stems are necessary. I've been told that they are OK on rubber valve stems..if so, I think I'll wait to replace them when I need new tires...
68 Overlander...are the sensors OK on the rubber valve stems (assuming they fit on non-angled stems with these wheels)?
TB
#3954
Old 04-07-2008, 12:34 PM   #13
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Has anyone had any experience with this tire pressure monitoring system I like it because it also gives tire temperatures, which from my old over the road days, I consider just as important as pressure. It is a little cheaper than the others too. I am considering ordering it for my eight tire motorhome.
Complete Trucking Website to help drivers optimize time, fuel, and tires. While increasing safety.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 04-09-2008, 09:09 PM   #14
Images: 21
TB
I just saw this today TB, didn't mean to ignore you. We (and PressurePro) prefer metal stems to prevent flexing of the stem. There have been no problems that I'm aware of but metal is just better all around. I would recommend anybody purchasing new tires to change to metal stems regardless of whether or not they are installing a TPMS.
Pressure Pro tire balancing needed? Camper Dave Tires 16 02-29-2008 08:17 PM
Turned off by the new Safaris Raptorrider2001 Our Community 17 09-08-2005 01:33 PM
SmarTire or Pressure pro? Sonia Tires 1 07-18-2005 01:32 PM
Doran Pressure Pro System JeepinAudiophile Commercial Listings 0 05-09-2005 10:19 AM
Do any recent 27' Safaris have dinettes? darkStar 2003 Safari 1 07-13-2003 02:17 PM
