Old 02-09-2016, 01:30 PM   #1
1999 28' Excella
New Orleans , Louisiana
Picture of an AS with 2 small wheels under the rear bumper?
Saw a AS blog yesterday and the pic of the AS. They were parked in Oregon and the AS had 2 smallish wheels not touching the ground under the rear bumper. Maybe they touch before the bumper would when backing up on unlevel ground.
Any thoughts?
badkat is offline   Reply With Quote
Old 02-09-2016, 01:47 PM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I had a car trailer that had those wheels, they hit the ground before the bumper to stop it from dragging on the ground, say for when backing up a steep driveway.
The way an Airstream frame is built, I would recommend against them, these trailers are not made to lift by the rear part of the frame.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 02-09-2016, 01:49 PM   #3
1999 28' Excella
This was a blog called "Just Five More Minutes" in their destinations of Oregon. Just looked again. Yes, I also would be worried about damage to the rear floor and bumper.
Old 02-09-2016, 01:52 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
A common application that has little or no merit. Yes those wheels will touch the ground before the trailer frame does but depending on the mounting of the wheels they will also touch the ground far more often then the trailer would. Some installations have the wheels 2 or 3 in. below the frame removing 2 or 3 in. of ground clearance
If you are willing to have those additional shocks applied to your trailer use them. It is far more effective to pay attention to the rear of your trailer, with your mirrors, than risk that additional damaging contact.
If you ever use a Canadian ferry you will want to pay attention to the rear of the trailer while loading and unloading. The ramps commonly have an incline so steep that it guarantees my 34 fter. slides on and off the ferry. Coming off Grand Manan Island the wheels came off the ramp
2004 Excursion 4x4
Old 02-09-2016, 02:45 PM   #5
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
As HowieE points out, rollers unnecessarily decrease your departure angle. Airstreams already have skids.
But then...
ALUMINUMINUM is offline   Reply With Quote
Old 02-09-2016, 03:00 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
FYI To all:
When using ferries of any sort anywhere, pay close attention to high and low tides. Try to schedule your embarking just before a high tide, and disembarking just after a high tide. The reason being is that at high tide the jetty ramps are at there most level point in relation to the wharf. When embarking or disembarking at or close to high tide the ramp is almost completely level; at low tide the ramp is at its steepness.
Cheers
Tony
Old 02-09-2016, 04:55 PM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Little wheels....
....not necessary, we all have 'skids', they may even cause more problems than not.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 02-10-2016, 11:07 AM   #8
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I believe that person had a very steep driveway and the wheels are used to help park his AS.
TinCan
graysailor is offline   Reply With Quote
Old 02-10-2016, 01:47 PM   #9
gecko's Avatar
2009 28' International
Pacific Palisades , California
Our first trailer was a box Fleetwood 30 ft, and the small wheels under the rear bumper were necessary to keep the traiker from scraping out of the very steep swale encountered when exiting our trailer storage facility.
When we purchased our new Airstream, we had similar wheels installed for the same reason. After careful observation, we found that they were superfluous--the standard skids do the job. The key is to make sure to exit at right angles to the dip (unlike what you do to protect the front spoiler of a low slung sportscar.) If you do it at an angle, the skids will bend under, but straight ahead they do the job. I have to believe that the "weaker" skids are better for the trailer frame than the strong wheels--rather bend the skids than bend the frame.
We removed the wheels after the first week and have not had an issue.
gecko is offline   Reply With Quote
Old 02-10-2016, 01:57 PM   #10
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
I am getting mine installed soon as well. My drive way is steep and I currently have to use a ramp. It is a pain in the ass to drag in and out. So the dealership recommended I get a wheel on my rear bumper to help. If you have a clear picture of it, would love to see it.
cazual6 is offline   Reply With Quote
Old 02-10-2016, 04:49 PM   #11
1999 28' Excella
Look up the blog Just Five Minutes and go under destinations and pick Oregon.
Old 02-10-2016, 06:48 PM   #12
2015 22' FB Sport
Wethersfield , Connecticut
I unfortunately experienced this upon arriving home only to find my New AS rear skids bottomed out on the drive apron. If I would have forced it the sewer outlet would have been history. Long story short regraded drive and sidewalk and a thinner wallet it is all good now. My point - skids would not have protected the sewer outlet.
TinkersToy is offline   Reply With Quote
Old 02-10-2016, 09:15 PM   #13
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Under extreme conditions, not necessarily visible in the TV mirrors, such as a cross road with asphalt surface and high crown, you can inadvertently back into the, not over, the rise with the skids. Now, if the forward room is limited you are stuck. Rollers would be better than nothing. However, my experience has been that rear quarter panel damage is inevitable because of the sharp upward force the flexing frame will produce. If I had not found a very small parking lot to turn all 57' around in, I would still be in the Arkansas woods trying to figure what to do on a late Sunday afternoon.
guskmg
Old 02-12-2016, 10:07 AM   #14
1976 25' Tradewind
Kimberton , Pennsylvania
Here’s something you might find in the auto parts store or catalog. Curb Feelers or Finders might help if you don’t have a person to guide you during a backup. When attached to the underside frame or shell they'll issue a loud metallic screech forewarning you that you need to check your clearance. They will be more forgiving than wheels and the brackets that hold them.
Curb feelers or curb finders are springs or wires installed on a vehicle which act as "whiskers" to alert drivers when they are at the right distance from the curb while parking.
Curb Finders or Feelers for automobiles: The devices are fitted low on the body, close to the wheels. As the vehicle approaches the curb, the protruding feelers scrape against the curb, making a noise and alerting the driver in time to avoid damaging the wheels or hubcaps. The feelers are manufactured to be flexible and do not easily break.
BicenTw is offline   Reply With Quote
Drag wheels instead of steel drag bars under bumper? rveillette Bumpers & Bumper Storage 12 04-13-2014 12:53 PM
Drawer under rear bumper leaks Cracker Exterior Storage Compartments & Access Doors 2 01-16-2013 10:19 AM
Small crunch in rear bumper on 2003 LY (gas) spat61 Land Yacht/Legacy Motorhomes 4 11-06-2007 07:38 PM
Backing up steep driveway-wheels under rear bumper? Wexus Off Topic Forum 12 03-16-2006 08:15 AM
