Old 04-19-2013, 10:52 AM   #85
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by polarlyse View Post
I'm another vote for the old style bearings. Easy to service. Easy to replace and can be done at the side of the road with minimum tools when necessary. Try to do that with the sealed units. NOOooooo. Not for me. I love new technology but until they get it right I'll stick with the old.
If I wanted to be able to replace nev-r-lube bearings by the side of the road I would bring a drum with a new bearing already pressed into it as a spare. Dexter sells drums this way and they have reasonable availability --- Airstream isn't the only one using them.
The main problem, as I see it, is that the parts are expensive. A standard hub and drum assembly is $85 (street) while the nev-r-lube assembly is $350 (street).
Old 04-19-2013, 10:56 AM   #86
dznf0g's Avatar
Oswego , Illinois
I just carry an extra bearing assembly. If I had to hobble along to the next town on three, I'd find a press and reinstall there. Not a big deal in my book. I really don't like working by the side of the road anyway. Don't trust all you guys not to run me over.
-Rich-
Old 04-25-2013, 07:26 AM   #87
dznf0g's Avatar
Oswego , Illinois
FYI, I decided I should probably carry a socket for the spindle nut as well. Couldn't find the size online, so I contacted Dexter. The reply was 1-1/4" for the disc setup with Nev-r-lubes.
-Rich-
Old 04-25-2013, 07:36 AM   #88
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Nice big Cresent wrench and a few extra cotter pins, side cutters are handy also. Crescent wrench is much more versital and spindle castle nuts are not known for being overly tight. My choice for a lug wrench is a 1/2 " drive break over bar and also carry a torque wrench with a few 1/2" drive extensions so adding an 1" 1/4 socket would not hurt, I am sure I have a few. Garage sales are your friend.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 04-25-2013, 07:54 AM   #89
SteveH's Avatar
Common Sense , Texas
I don't have discs, but did actually measure mine at 1 7/16" with a caliper.
These nuts are not Castle nuts, and I don't think a big "All 1/16" wrench will work/reach into where the nut is, and there is no cotter pin, only a circle clip that prevents the nut from ever falling off the spindle. The nut is supposed to be torqued to 140 lb. ft.
I've tried to find an 1 7/16" socket around here in 1/2" drive, but all I can find is 3/4" drive, and would like to stay with 1/2".
Regards,
Steve
Old 04-25-2013, 08:20 AM   #90
dznf0g's Avatar
Oswego , Illinois
Steve, I found a 1/2 drive, 1 7/16" (which I now have to take back) at a regional chain here called Blaine's Farm and Fleet. (one of my favorite big boy toy stores!) They only had it in an impact socket. Armstrong is the brand. Not sure why this size is so rare?????? It was $19.99.
Apparently there is a difference in Drum vs. Disc setup. I too think you need a socket for this job, due to torque and reach into the hub.
Guess you could order it....
http://www.farmandfleet.com/products...l#.UXk7zEpQ3AI
-Rich-
Old 04-25-2013, 09:01 AM   #91
dznf0g's Avatar
Oswego , Illinois
wooooopppps, when I asked for clarification, Dexter rep did not make a fat finger mistake on my size question, he just misunderstood my question. This is the sizing for the disc/Nev-r-lube setup.
"No. It has a thread of 1”-14. It takes a 1-7/16” 6 or 12 point socket to remove it."
-Rich-
Old 04-25-2013, 10:35 AM   #92
1976 31' Sovereign
Oswego , Illinois
If 3/4 drive socket is less money then buy a simple 1/2to 3/4 adapter, they are cheap
Old 04-25-2013, 10:45 AM   #93
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I just ran i to a problem with an SOB fifth wheel using Nev R Lube bearings that I thought I would share.
The issue is the customer replaced his loaded backing plates, and the magnets were of the new oversized oval Dexter variety. The upper edges of the magnets were obstructed by the ridge on the drum where the bearing slips into the hub. The result was the magnets couldn't contact the friction area to apply the brakes.
This is something to look closely at when replacing magnets or loaded backing plates.
Old 04-25-2013, 10:51 AM   #94
Well Preserved
1993 21' Sovereign
Here is a photo of the old and new brake assemblies. I can't provide a photo of the drums, as they are at the machine shop being turned.
Old 04-25-2013, 10:52 AM   #95
Well Preserved
1993 21' Sovereign
Okay, I guess the ipad can only attach one photo per post for some reason. Here is a photo of the new one:
Old 04-25-2013, 11:00 AM   #96
Jim Clark's Avatar
Armstrong 1/2" Drive Deep Impact Socket (Size: 1-7/16") at Blain's Farm & Fleet
Must be the newer trailers, I have never looked at my 28. The 2005 Safari had Castle nuts and cotter pins, I still have a set in a bag. I bent an axle and the new one came with castle nuts.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 04-25-2013, 12:00 PM   #97
dznf0g's Avatar
Oswego , Illinois
For Nev-r-lubes, Jim? Or regular repackable bearings, or Easy lubes?
-Rich-
Old 04-25-2013, 12:19 PM   #98
Jim Clark's Avatar
The new trailer has the Nev-r-lubes the 2005 Safari had the regular, that is were the Crescent wrench came in. Some days I feel like a fleet mechanic.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
