My question is, what is the outside dimension of both tires?
The tire on a 2018 is likely to be similar to previous year, but it is ST225/75R15.
I'm trying to get a wheel cover that covers both wheels rather than individual wheels.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
I don't need exact measurements, just measure the OD of your tandem to get me an idea what it is. I understand it will little more or less.
WBCCI 9164
2000 25' Safari
Davidson County
, NC Highlands County, FL
I just checked my 25' Safari. It measures ~60" (~28 1/4" tire + 4 1/2" space + ~28 1/4" tire)
add edit: I know that the space between the tires can vary between Airstream models. I bought aluminum tire chocks that would not fit the space between the tires on one trailer but would fit another, both had two axles. My Safari had the larger space.
Alan
2017 25' International
Niagara-on-the-Lake
, ON Canada
IF you want to go all out you can purchase some of the same Sunbrella material as your awning and have a boat canvas shop make covers. You could get them fitted for the wheels or as I have seen on others made with dome fasteners to snap on over top of the wheel well.
. . . I know that the space between the tires can vary between Airstream models. I bought aluminum tire chocks that would not fit the space between the tires on one trailer but would fit another, both had two axles. My Safari had the larger space.
Hence the wisdom of waiting for the arrival of the new 2018 25' model, in order to measure things up, for such a minor add-on accessory IMO.
