Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels, Hubs & Bearings
Old 10-17-2017, 12:14 AM   #1
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Outside dimensions of a tandem wheel
As mentioned, I just purchased a 2018 FC 25 RT.
My question is, what is the outside dimension of both tires?
The tire on a 2018 is likely to be similar to previous year, but it is ST225/75R15.
I'm trying to get a wheel cover that covers both wheels rather than individual wheels.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 10-17-2017, 03:18 AM   #2
Sag Harbor , New York
Wouldn't it be easier to measure your actual AS after you get it, instead of everyone speculating about unknown things?
Among other unknowns, what parts of the suspension and braking systems might conflict with a tire cover which will span both wheels on each side?
Great choice of trailer by the way. We had a 25' back in the 90's, with a rear corner bed. The twin floor plan would make more sense for us now.
Congratulations on the move up!
Peter
Old 10-17-2017, 11:32 PM   #3
Stay CazuaL
cazual6's Avatar
Reseda , California
Peter,
You've seen a few of my posts. I don't easy ��.
I wanted to buy all the things prior to arrival.
I don't need exact measurements, just measure the OD of your tandem to get me an idea what it is. I understand it will little more or less.
WBCCI 9164
Old 10-18-2017, 06:22 AM   #4
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I just checked my 25' Safari. It measures ~60" (~28 1/4" tire + 4 1/2" space + ~28 1/4" tire)
add edit: I know that the space between the tires can vary between Airstream models. I bought aluminum tire chocks that would not fit the space between the tires on one trailer but would fit another, both had two axles. My Safari had the larger space.
Alan
Old 10-18-2017, 08:14 AM   #5
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
These worked good for ours;
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 10-18-2017, 09:24 AM   #6
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
IF you want to go all out you can purchase some of the same Sunbrella material as your awning and have a boat canvas shop make covers. You could get them fitted for the wheels or as I have seen on others made with dome fasteners to snap on over top of the wheel well.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 10-18-2017, 01:46 PM   #7
Originally Posted by A W Warn View Post
. . . I know that the space between the tires can vary between Airstream models. I bought aluminum tire chocks that would not fit the space between the tires on one trailer but would fit another, both had two axles. My Safari had the larger space.
Hence the wisdom of waiting for the arrival of the new 2018 25' model, in order to measure things up, for such a minor add-on accessory IMO.
Patience . . .
Who uses tandem wheel chocks? Splitrock Brakes & Brake Controllers 64 11-24-2021 07:12 AM
Rub rail above tandem wheel wells for '72 LY Overlander Autumn Aire Airstream Classifieds 0 08-08-2017 11:22 PM
Airstream Wheel Well, Tandem 66.50" A.B.S. (set) GABEMARONEY Airstream Classifieds 0 04-02-2016 11:32 AM
2013 International Tandem Wheel Set dsaxon22 Airstream Classifieds 3 02-06-2014 04:42 AM
Single vs. Tandem and Smallest tandem axle JimGolden Airstream Trailer Forums 27 11-29-2009 09:04 PM
