Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Prev Previous Post   Next Post Next
Old 10-07-2009, 07:37 AM   #1
unhitched
cvkey's Avatar
Profile:  1963 19' Globetrotter
Knoxville , Iowa
Original Steel Wheels? '63 GT
After dragging a '63 Globe Trotter out of the woods near Truman Lake MO. and getting home, 500 miles on a nearly frozen axle, I removed the wheels, axle and a few other things - of course!
I took the wheels up to get them broke down and here was my surprise...
The spare tire was a 7.00-15LT LR-C tube type bias ply mounted on a steel rim stamped 15x6L inside. This rim has the clips for a hub cap, 6-lug holes and a center hub hole of about 3 5/8".
The left tire was a 7.00-15LT LR-D tubeless bias ply mounted on the same kind of rim as the spare above.
The right tire was a 7.00-15LT LR-D tubeless bias ply mounted on a different size rim *WHAT THE HECK*
The rim is not stamped inside, it is the same 6-lugs, same 3 5/8" hub hole, BUT it is a 5" wide steel rim and about 1/2" less in diameter.
Are these 3 rims original? Was the smaller rim suppose to be the spare? with a different size tire? How the heck would a 7.00-15LT even stay on the smaller rim for 500 miles? Is there any reason I could not put new radials on these rims? The 2 rims that are stamped inside 15x6L - what does the 'L' designate?
Any help is appreciated...
Picasa Web Albums - Charlie - Airstream
'63 Globe Trotter 19'
WBCCI 11953
Air#39812
cvkey is offline   Reply With Quote
Replacing my wheels/Steel vs. Aluminum Foiled Again Wheels 2 09-16-2009 01:36 AM
Steel vs. Aluminum wheels HansenClan Wheels 5 09-15-2009 03:45 PM
Original Stainless Steel Bowen water heater door adonh Water Heaters, Filters & Pumps 0 02-11-2008 11:29 AM
Airstream steel wheels davidz71 Our Community 5 05-23-2002 08:50 AM
Airstream steel wheels davidz71 Wheels 0 05-21-2002 06:18 PM
