Old 02-16-2015, 06:40 PM   #29
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Originally Posted by Top View Post
John,
If the data plate reads 50psi, then it came with Load Range C tires.
You won't have a problem with the Michelins.
Can they take the sidewall stress from twisting and turning?
thanks.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 02-16-2015, 06:46 PM   #30
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I've never had a problem, but I don't have a 34'er. If that is a major concern for you, I'd go with the LT 215/75/15 Good Year Wrangler HT LRD. They are a very robust tire.
Lance
Top is offline   Reply With Quote
Old 02-16-2015, 06:56 PM   #31
sandlapper's Avatar
1993 34' Excella
thanks lance...now one more tire to consider!!
Homework is never done, so just go to bed!!
John
John
Region 3 , 1st VP
Are you kind?
Old 02-17-2015, 06:19 PM   #32
sandlapper's Avatar
1993 34' Excella
OK, not reading anymore.....descision made...
.......I'm going with the Michelins.
Thanks everyone for the feedback. I will follow up later.
John
John
Region 3 , 1st VP
Are you kind?
Old 02-18-2015, 12:36 AM   #33
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
When I upgraded to 16" tires & wheels, I did so at JC. The factory had a deal - about $300 each for a 16" Sendel wheel with Michelin LTX225/75R16(e) tires. I run them at the rated 80psi (which is what JC recommended). They did have to do some minor modification to the spare tire holder so that the new wheel/tires would fit. Prior to the upgrade I had 2 ST tires fail in the past year (both were less than 2 years old from date of mfr), resulting in having to have JC fix a wheel-well.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 02-18-2015, 06:01 AM   #34
1965 mustang's Avatar
Stoughton , Wisconsin
Would the Goodyear LR D at 65 psi ride smoother than ST tires at 65 psi?
1965 mustang is offline   Reply With Quote
Old 02-18-2015, 06:26 AM   #35
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I'm guessing you are referring to the GoodYear Wrangler HT LT215/75/15 LRD. Yes?
It would depend a lot on which ST tires you are comparing. Maybe you could, but I doubt you would be able to tell the difference.
Lance
Old 02-18-2015, 08:15 AM   #36
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Another tire to consider would be the General Grabber HTS in the 235/75/15 size. It has a an XL rating, index of 109t and load rating of 2271 lbs before derating.
We put these on a cargo trailer in the fall of 2014. They had no trouble or heat build up and was towed at much higher than legal speeds than I care to mention (not by me of course).
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 02-20-2015, 07:55 PM   #37
Opinion on tires
I was really happy with the MX2's on my 05 tundra. They lasted forever and were very smooth and quiet.
Old 04-09-2015, 11:51 AM   #38
Aparently the michelin LTX 235/75/15 is only available in the M/S 2 and not the AS. Anyone see a problem with a little more aggressive tread pattern?
Old 04-09-2015, 12:16 PM   #39
dznf0g's Avatar
Oswego , Illinois
Nope, I have that size on my van. Smooth and pretty quiet. They'd be my choice for a smaller trailer.
-Rich-
Old 04-09-2015, 02:17 PM   #40
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Nope!
Name:	ImageUploadedByAirstream Forums1428610623.199164.jpg
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-09-2015, 03:07 PM   #41
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"Would the Goodyear LR D at 65 psi ride smoother than ST tires at 65 psi?"
Not sure. But the point is they are more likely to have air in them and be in one piece than the ST tires which sure helps the ride overall.
Bill M. is online now   Reply With Quote
Old 04-09-2015, 04:20 PM   #42
That's a good point bill.Lol! I'm torn between the Michelin LTX and Goodyear wrangler LRD. The Michelin is about $20.00 cheaper per tire plus $70.00 rebate on the set of 4. But I don't want to go cheap and be sorry later.
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
Opinion Wanted - 205/75R15 Tires mello mike Tires 8 07-17-2010 08:15 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
