Old 11-19-2007, 10:58 AM   #1
healthchic's Avatar
2004 19' International CCD
haines city , Florida
Question Oil bath wheel bearings
Has anybody converted standard grease hubs to an oil bath lube system?
I'm thinking of upgrading my 04 bambi "THE HEALTH CHIC"
the other half of the healthchic, Bill
healthchic is offline   Reply With Quote
Old 11-19-2007, 01:21 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Have not heard of anyone doing this, but have seen them advertised for boat trailers. I have never had a problem with greased bearings, and I have 4 trailers, boat, A/S, utility flatbed and horse. My utility trailer has gone the longest, without any service, about 9 years!
That being said, I have seen some failures due to lack of PROPER service. One trailer, a friends gets used commercially, just about every day. It died from OVER greasing, after one of his goombas blew a seal out with a grease gun. The other from someone who did not know what they were doing when they repacked and put the bearings and races in backwards.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-19-2007, 01:32 PM   #3
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Texas T
I would go for it...
Like above, never done a conversion, did have them on 18 wheeler and they last forever.
I think they help wit cooling and keep bearing in lube.
Easy to top off when low too...no special gun needed.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 11-19-2007, 04:12 PM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Years ago all Big Trucks had axles that were Greased Bearings. About 30 yrs. ago or so Someone invented the oil bath bearing with is still in use today. But I have not seen It for axles of the size of the Henschen or Dexter axle used on AS. It would be very convenient. They have a sight glass where U can see the oil level and a rubber bung U can pull off and fill them with oil. they do take a little different rear seal but they are not that expensive.
If anyone has seen such a setup Im intrested. I do have a converted jet-ski trailer that I use to pu/del yardtractors and it has Bearing Buddys that U fill with a grease-gun. I grease em once a yr or when they get low,it has a spring loaded plate with the grease zurk in it.U fill till the plate reaches the outside end and its full. I never have had a overfilling problem with them but I heard they are not good where brakes are innvolved.
Roger
Mikethefixit is offline   Reply With Quote
Old 11-19-2007, 04:51 PM   #5
Land Rover has recently "uprated" the servicing of the oil bath bearings on the front axle of my Land Rover Discovery by stating that they should now be filled with grease instead of oil. This notice was accompanied by two small sachets containing the correct quantity and type of grease. Plus ca change, plus c'est la meme chose.....
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 11-19-2007, 04:56 PM   #6
Images: 59
If you can find the parts I would do it in a minute. I took a quick look at the Dexter axle site and it looks like you can order oil lube on a 6000# axle with 12"x2" electric brakes. However, I'm not sure it comes on the Troflex axles, it may only come on leaf spring axles.
Old 11-19-2007, 05:23 PM   #7
1977 27' Overlander
Trotwood , Ohio
I just looked at the GKN site and a cut away view of the axle and I'm reasonably sure that Henschen(GKN) now offers a greaseable axle as does Dexter. I'm sure if I have assumed incorrectly that ANDY will offer his expert/hands on Wisdom.
Roger
Old 11-19-2007, 06:42 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Because grease won't leak as readily as oil?
Why don't the British build computers? Because they haven't figured out how to make them leak oil.
Sorry for the British car joke- my first car was an LR and I loved it ('67 Series IIA).
Old 11-19-2007, 07:38 PM   #9
_
the brit joke is no joke,
just the truth.
hi chic...
why the oil bath?
the friction isn't significantly different , grease is basically oil + soap.
harder to keep them from leaking and IF a leak developed it might affect the brakes...
when parked (stored) the bearings will not have better protection with a oil bath..
imo the nifty upgrade is disc brakes and nev-r lube hubs with 100k bearing sets...
if you can get that combo.
cheers
2air'
Old 11-19-2007, 07:49 PM   #10
Hey, I've got some Lucas electric spares you might find useful.....
Nick.
Old 11-19-2007, 07:57 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i'm glad you have a good sense of humor nick!
john
you call them ferrets, i call them weasels.
Old 11-19-2007, 08:29 PM   #12
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Lucas, the Prince of Darkness. I had an MG.
LJH is offline   Reply With Quote
Old 11-19-2007, 08:35 PM   #13
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Oil Vs Grease
Actibrake used oil and mine and several other's leaked within 1000 miles.
Actibrake paid too have them returned too grease.
In my openion there wasn't enough oil in the small space too cool and that's what caused the seals too melt.
Gunny
Gunnyusmc is offline   Reply With Quote
Old 11-20-2007, 05:46 AM   #14
lewster's Avatar
Naples, FL , Hood River, OR
Yah! Ain't it the truth!
I has 2 Jags, an MGB and a Triumph TR-6. I guess you could call me a glutton for punishment!!!
Wheel bearings Allen H Axles 18 10-31-2007 04:12 PM
Wheel bearings FlyingW Axles 3 07-01-2006 05:36 PM
Wheel Bearings 76ArgosyDave Axles 7 06-29-2005 03:00 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
