Old 07-01-2010, 10:03 AM   #1
1973 25' Caravanner
La Quinta , California
Send a message via Skype™ to mark2010
Offset for Aluminum Rims
Can anyone help me with what rim/tire combo would work best on a 1971 27' Airstream Overlander International. Can I purchase 15x7 centerline rims with ST 225/75 R15 tires as a good combination?
I am new and would appreciate any advice...thank you
mark2010 is offline   Reply With Quote
Old 07-01-2010, 12:01 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I can not comment on the older rim offset but what I would suggest is take one of your current rims into any tire store that sell aftermarket rims and ask them to measure the offset.
2004 Excursion 4x4
Old 07-01-2010, 12:26 PM   #3
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
I could be wrong, but I believe they are zero offset. I know the backspacing is 4 inches. I just installed a set of standard 6-lug alloy trailer wheels with 225/75/15 tires that I purchased through a local utility trailer dealership on my '69. The tire size is perfect.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-01-2010, 12:37 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I think zero offset is correct
Old 07-01-2010, 12:55 PM   #5
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Don't know if it helps, but the offset on the newer trailers is 0. I just purchased a set of aluminum whees from Aluminum Trailer Wheels these folks, I found them very helpful and I'll bet they would know the answer, I think they work a lot with Airstream owners.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 07-01-2010, 01:26 PM   #6
richinny's Avatar
2011 34' Classic
i think they also should be rated around 2600 lbs.
this thread should be helpful:
http://www.airforums.com/forums/f465...ade-40248.html
Ricky
Old 07-01-2010, 11:13 PM   #7
1973 25' Caravanner
Thanks it is 0
rims, tires
1966 Caravel: Best New Tires; Old Rims or New Rims??? divotvance Member Introductions 6 08-11-2016 07:43 AM
15" Aluminum rims & Centramatics davidz71 Wheels, Hubs & Bearings 22 01-10-2010 01:57 PM
Offset for 16 inch rims Cos Wheels, Hubs & Bearings 6 07-30-2008 11:25 AM
New Aluminum Rims for 1991 29' Excella brodjeaw Wheels, Hubs & Bearings 3 05-07-2007 10:18 AM
Aluminum Rims on 85 Limited robandzoe Wheels, Hubs & Bearings 4 05-06-2004 09:05 AM
