Old 07-29-2008, 02:19 PM   #1
Cos
1973 21' Globetrotter
Middletown , Rhode Island
Offset for 16 inch rims
If I change to a 16 inch rim on a '73 Globetrotter (for the improved tire selection) can I continue with a zero offset wheel?
Cos is offline   Reply With Quote
Old 07-29-2008, 03:17 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Ask the Master
I don't see why not. Member markdoane told me the wrong offset only affects the tire rubbing on the shock mount or fender. PM him for additional insight.
I'm assuming the wheel is the only thing changing and NOT the tire diameter (wheel-well interference)
Tom
p.s. If you do PM markdoane, start your missive with "Oh great one! Please share your infinite knowledge with this unworthy one!" markdoane eats that stuff up.
Old 07-29-2008, 05:39 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
When I changed to 16 in. wheels I had to use one with a 5mm+ offset to keep from rubbing the fender with the E rated tires.
I do know that the vendor I used has supplied many Airstreamers with 16 in wheels and could answer the question.
http://www.trailertiresandwheels.net...78/page/910764
2004 Excursion 4x4
Old 07-29-2008, 08:00 PM   #4
1984 31' Excella
Broken Arrow , Oklahoma
Images: 11
Wheel
When I measured the steel Airstream wheels I found all five to have a 8mm offset.
The Eagle Alloy Rims I went with have a 8mm offset.
Model 0589-7766-1-AA
Beginner
Beginner is offline   Reply With Quote
Old 07-29-2008, 09:29 PM   #5
newbie
audiobox's Avatar
Fort Wayne , Indiana
Hmmmm. The Dexter axle I ordered with the Nev-R-lub hubs is in and will be installed in a few weeks. Dexter specifies zero offset with those hubs. The Michelin LT225/75RR-16 Michelin LTX M/S E tires arrived today. Yesterday, I ordered a pair of 16" steel rims with zero offset from http://www.trailertiresandwheels.net...78/page/910764
After seeing this thread, I called and left a message asking them to call me about my choice. I wonder if the hubs have painted me in a corner where the tires are going to rub.
https://www.septaudio.com
audiobox is offline   Reply With Quote
Old 07-30-2008, 11:20 AM   #6
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
Keep us posted Audiobox. I too just installed a Dexter Nev-R- Lube axle, but am currently using the stock rims.
Gkiesel is offline   Reply With Quote
Old 07-30-2008, 11:25 AM   #7
newbie
audiobox's Avatar
Will do. I talked to Scott at Trailer Tires & Wheels this morning and he didn't think there would be a rubbing problem. He confirmed the recomended zero offset recomended with the Never-R-Lube hubs. Installation is in about two weeks. I'll report back.
1966 Caravel: Best New Tires; Old Rims or New Rims??? divotvance Member Introductions 6 08-11-2016 07:43 AM
10 or 12 Inch Brakes??? Sundance Brakes & Brake Controllers 8 07-10-2007 05:04 PM
Correct wheels and offset bhayden Wheels, Hubs & Bearings 2 06-25-2007 01:45 PM
wheel offset ON SAFARI Wheels, Hubs & Bearings 7 06-03-2004 08:35 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
