08-12-2013, 07:29 AM
#41
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
There was an improvement in the Dodge ride and no vibration in the steering wheel after the Centramatics were installed.
I had the Airstream compatible "200-221 Special" Centramatics installed on my 25FB before I picked the trailer up and continued with them after switching from the GYM to the Michelin tires. Even if it just a slight improvement, the $200 is not a great expense compared to the $80,000+ list price of the trailer.
I have the "300-356" Centramatics (only for 16" wheels) on order for our new 27FB and I will install them along with the 16" Michelin tires and SenDel wheels.
08-12-2013, 07:48 AM
#42
2012 25' Flying Cloud
Battle Lake
Switz, you're most probably aware of the small offset the Centramatics give when installed under the wheels, and the advisory not to offset wheels with the Never Lube bearings. I'm having trouble reconciling that incompatibility, even as small as it seems. How do you feel about it?
doug
08-12-2013, 07:59 AM
#43
2008 25' Safari FB SE
Victoria
, BC
Originally Posted by Gene
I'd like to have the sort of information Evan wants about lots of things Airstream, but no one does that sort of testing. The RV market is too small to spend the kind of money necessary to do good testing.
So, like many decisions, it is a guesstimate and I hope my $200 was well spent.
What I really need is Centramatics for the brain so I won't be unbalanced anymore.
Evan, when you get the new Michelins, the trailer should ride smoother than with the Marathons, so if you add Centramatics at the same time, you won't be able to tell what is responsible for the improvement.
Gene
Hi Gene,
If we were talking about reducing wheel vibration in the tow vehicle (like switz's Dodge truck) at least the driver & & passenger can make a subjective comment about how smooth the vehicle 'feels'. Better yet would be to do some double blind testing of multiple vehicles for both the subjective sensation & actually measuring vibration etc. (Observer bias is a real issue in any sort of question like this,)
Now remove the subjective sensation from equation; the wheels being treated are not attached to a passenger vehicle but the trailer. No one rides back there... ( I don't think). So how would you know whether there is any benefit from the Centramatics? Yes, the new tire/wheel combo could be inherently smoother than the old setup.... Maybe not. Around here we have lots of twisty mountain roads & hills. I always assumed that the pillows on the floor after a ride were due to the twists in the road not the wheel vibration. How would I know? ( maybe we had some hitch-hikers in a hurry to get out when we stopped?)
But, you're probably right. No one seemingly wants to spend the time & money to address this question and its quite possible that the stakeholders don't really want to know the answer.
This could be like many issues in Medicine where when something that makes a lot of sense is finally examined in a controlled double blind fashion, it turns out to be useless or even harmful.
I'm thinking that if I do decide to get the Centramatics (based on the common sense notion that might help keep things balanced better over time), I will devise a test setup to try & measure whether they make any difference at all to my own unit.
I'm thinking that I could place my iPhone in the trailer, set up as an acclerometer. Secure a video camera strapped down on the trailer table or countertops. Drive a certain stretch of road at a controlled repeatable speed several times while recording video & movement.
Do this with old tires & wheels.
Repeat - post new tires & wheels.
Install Centramatics & repeat again.
Report how much difference this has made to ride quality & then try & guess* whether it makes any difference to tire longevity or rivet life (or overall happiness in the life of the trailer. )
It would have only limited validity in terms of how much any one could extrapolate the results to their own setup. It also would not address the question of whether the Centramatics effect would be more valuable over time as the tires wear & stones get caught on the tread etc.; but it might be better than nothing.
If they don't work. I will take them off & wear one on my head to see if I can think straighter. I only need one though. Do you want me to send you one of the surplus for your head too? ;-) Maybe we could be on to a new dementia preventative. (Arguably; in my case, treatment.) Since it would be a medical device we could re-sell them for at least $10,000 a pop. We'll be rich!
- evan
08-12-2013, 09:18 AM
#44
1999 34' Excella
Hillsboro
Perhaps a few could get together and arrange a "test day".... I think there are a few around who might give solid feedback.
Peace and Blessings..
Channing
WBCCI# 30676
08-12-2013, 09:20 AM
#45
1999 34' Excella
Hillsboro
If you had 6 I would buy "em off ya... I need to install on all AS wheels.
Channing
WBCCI# 30676
08-12-2013, 10:58 AM
#46
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I use centramatics on the trailer and have used the dyna beads as well. I am a believer in the centramatics. At one point I used both simultaneously simply because I had the beads first. Now it is just the centramatics.
One BIG note of caution. In reference to the dyna beads. I put them in my wife's Honda Odyssey running standard P tires. after about two months she had three tread separation events within a two week timeframe. I can't prove it was the beads, but this is the only time I have seen tread separation to this extent. I DO NOT recommend them for the weaker passenger tires. The stronger trailer tires appear to be OK.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
08-12-2013, 11:36 AM
#47
Battle Lake
Could the dyna beads wear through the inside tire casing allowing air to leak between the tread and casing, causing tread separation.
Maybe, but were they indeed the product Dyna beads? In their advertising they suggest their round ceramic beads will not damage the inside casing, but other poorly manufactured beads will.
doug
08-12-2013, 12:40 PM
#48
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
They were 100% genuine Dyna Beads ordered directly from the company and installed exactly per their instructions. The amount added to each tire was within .01 grams in weight.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
08-12-2013, 01:10 PM
#49
1981 31' Excella II
New Market
, Alabama
Ok let's make this easy. Put some Centramatics on the rear end of an auto and jack the rear end up off the ground (assuming rear wheel drive). Put it in high gear and get it up to highway speeds as indicated by the speedometer. You will be able to see and feel the vibrations from any out of balance wheels. You can purposly remove or add weights to see if the Centramatics can fix the out of balance condition.
Perry
08-12-2013, 01:31 PM
#50
Master of Universe
Grand Junction
Evan,
I can't wear a Centramatic on my head since I have a pyramid there to focus energy into my brain and make me brilliant. It hasn't worked yet, but I'm hoping it will.
Our trailer appears to ride better than when we bought it according to the pillow test. We find them askew or on the floor far less often, but I can't remember (pyramid still not working) if it got better after the Centramatics or after the new tires (the tires came after the Centramatics). I kinda think each change made the pillows stay in place a little better. We also had some rivets pop early on, but once I replaced them, they have stayed in—was it because I put them in better than the factory guy, because of the Centramatics or because of the tires?
Gotta go and adjust the pyramid.
Gene
Gene
08-12-2013, 02:01 PM
#51
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
.....how about a tire that comes from the factory with beads in the beads.
"You don't know where you've been until you leave, enjoy life" RLC
08-12-2013, 02:41 PM
#52
1967 26' Overlander
Huntsville
, Alabama
But He's FOR REAL!
Originally Posted by ROBERT CROSS
But Dave...it's a blog on the interweb, it must be accurate.
My cousin's step-uncle told me that guy is really, really, REALLY good. He says he's the guy Colin, Terry, AND Andy go to for the tough stuff.
Tom
08-12-2013, 03:18 PM
#53
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
I can comment only from personal experience.
We purchased a new trailer and traveled about 12K without Centramatics.
I replaced a couple broken rivets in the new trailer during this time.
We had an '81 model before the new trailer, and replacing broken rivets was a fairly common thing.
With those thoughts in mind, and a little research, I purchased a set of Centramatics and installed them.
We now have over 40k and I have not replaced a rivet or tightened a screw.
I have replaced a set of tires, but am still running 15" ST, though not
Marathons.
Considering $2500 for an upgrade to 16" and LT tires, what is 10% +\- for a little insurance?
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
08-12-2013, 03:26 PM
#54
2014 31' Classic
Apache Junction
I am not worried. I am more concerned about avoiding vibration damage than the slight chance of an axle issue. And Never Lube is an advertising gimmick word that bears watching and annual service anyway of the brakes and hubs. Maybe if all the parts were not purchased from the lowest bidder, we would have brake drums that were balanced to begin with like on autos and trucks.
With the Centramatics, I am compensating for too cheap parts on a $100,000 trailer which sounds nuts to me.
08-12-2013, 03:56 PM
#55
Victoria
, BC
Good points here...
So the Airstream differs from autos not just in its lack of waterproofing but also in that unlike automobiles, the drums & running gear are not balanced at the factory?
Pretty sad really.
- evan
08-12-2013, 04:01 PM
#56
Victoria
, BC
Marathons.
Regards,
JD
Thanks JD.
I agree that in the grand scheme of things $200- ain't much.
I do have a few rivets that pop occasionally & many of the cushions will be on the floor after a highway run; but I always attributed that to rough & twisty roads not wheel vibration.
I appreciate hearing of people's experience.
I still think some simple objective tests would be a big help.
- evan
08-12-2013, 04:30 PM
#57
1967 26' Overlander
Huntsville
, Alabama
And Who Will Foot the Bill?
Originally Posted by eheffa
...I still think some simple objective tests would be a big help.
You will not get simple objective tests unless you pay for them.
Tom
08-12-2013, 04:34 PM
#58
Victoria
, BC
Tom
Or do it yourself. ;-)
08-12-2013, 05:34 PM
#59
1981 31' Excella II
New Market
, Alabama
It is the manufacture's job to test their products before releasing them to the market. Many times they don't want you to see their test data. Oh you would not understand it they say. They want to market an ideal product not real test data that can't be exaggerated or distorted into whatever they want it to be.
Perry
08-12-2013, 06:26 PM
#60
1985 31' Excella
Seguin
I installed my first set of Centramatics on a motorhome about 18 years ago. The tires on that motorhome were bias truck tires. They would develop flat spots and would shake like crazy for the first few miles on a trip. Someone told me about Centramatics.
I don't usually ride in my Airstream trailer, but I did drive that motorhome. it ran smooth as silk after the Centramatics were installed.
A new set of tires and Centramatics were the first thing I installed on my Airstream.
