Old 03-19-2008, 02:52 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Next step wheel studs
In order to replace my old wheels with new Aluminum wheels I will need to install wheel studs to replace the old lug bolts.Here is a link with a picture of a wheel stud.
Replacement Wheel Stud, Screw-In, 1/2" x 2" 25-53 : Trailer hitch bike rack and trailer hitches - etrailer.com
Notice the small raised non threaded section. The short threaded section screws in to the drum up to the raised section. In order to assure a flush fit between the wheel and drum it will be necessary to countersink the 1/2 lug holes holes so that when the wheel is tightenecd on the drum the raised section is not sticking out preventing a flush connection.
Is there a countersink 9/16 bit that will cut the metal on the drum that I could use in a handheld power drill to shave less than an 1/8" to accomplish this.
Don
adonh is offline   Reply With Quote
Old 03-19-2008, 03:17 PM   #2
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Don
Hi Don; I would not recommend that you use a 9/16" drill as countersink bit in a 1/2" bore. The standard drill will grab and jamb into the 1/2" hole, damaging the drum and possibly cause you an injury. For that job you should find a metal countersink bit. Trust me on this one. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 03-19-2008, 03:23 PM   #3
adonh's Avatar
1976 31' Sovereign
Yes I knew a standard drill bit would not work. Where would I find a "metal countersink bit". I did not get much from Google.
Don
Old 03-19-2008, 03:45 PM   #4
adonh's Avatar
1976 31' Sovereign
I am assuming that the drum would need to be countersunk slightly at the lug holes. Am I wrong in this assumption or will the wheel holes slip over this unthreaded spot.
Don
Old 03-19-2008, 04:43 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The wheel should slip right over the unthreaded portion. The OD of the threads is generally the same size minus a tad as the unthreadesd portion of the stud. It is actually better to have the wheel not come into contact with any of the threaded portion of the stud. The threads can damage the bore of the aluminum wheel. The only portion of the assembly that should touch the wheel is the OD of the lugnut.
Old 03-19-2008, 06:54 PM   #6
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Metal Countersink Bit
Aerowood,
How about here...
Countersink Bits from Irwin at Van Sant Enterprises, Inc.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-19-2008, 07:57 PM   #7
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 220
I started to do this modification a year ago to get the aluminum wheels on before a rally and ended up just replacing the entire axles, as I was going to do so anyway. I purchased black threaded rod and cut it approximately the same length, but just didn't get the warm fuzzy after talking with a few mechanics. I still have a bunch of them in the garage.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 03-29-2008, 05:46 PM   #8
adonh's Avatar
1976 31' Sovereign
Update on the wheel studs
Disount Tire is installing the new wheels and tires next week. They have a chrome plated lug bolt that looks very similar to a chrome lug nut when insatlled. I will post pictures of the wheels and tires when its all done.
Don
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
New brake drums or studs????? bhayden Brakes & Brake Controllers 2 05-08-2007 04:13 AM
Why should I convert my bolts to studs and nuts? lebolewis Wheels, Hubs & Bearings 22 05-04-2007 10:33 AM
1969 Safari shock absorber studs tom westlake Axles 6 06-03-2006 12:03 PM
