02-15-2005, 05:28 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
New Rims
I looked at my rims this past week while repacing the bearings. 2 are in need of replacing. I have a '75 Duel axle Trade Wind. What size, bolt circle and load rating do I need to look for????
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
02-15-2005, 10:39 AM
Corona
balgrn
The correct wheel is 15 inch with a 6 on a 5 1/2 inch bolt circle, with a 7 inch width.
They also must be a minimum of 2600 pound rating.
We have them if you cannot find them locally.
02-15-2005, 03:06 PM
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Thanks, I found them on your site! I'll keep it on the list if I can not locate here.
www.balrgn.com
02-15-2005, 09:14 PM
1959 22' Caravanner
Atlanta
, Georgia
If you want to spiff it up.
http://www.trailer-parts-forless.com...l_assembly.htm
22575R15ARA is the correct part number for the ones that will fit with 6 lugs and a 2500lb weight rating. These ARE trailer wheels. Comes with GoodYear marathons and appears to be the same wheel Airstream now uses on new coaches. I have a set in my garage ready to go on my 59. Don't order the lug nuts from them. They don't carry the correct ones.
I happen to be reasonably local to that company. Check you local trailer supply places. Thats a pretty common wheel. Save the shipping buying local.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
02-16-2005, 05:15 AM
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Those sure are purdee! All my tires are like new. I did find a site that has rims @ a pretty good price.
http://www.lowcosttrailersupplies.co...ory_Code=OEMSW
Looks like Part # WH156-60E is the one I am looking for. I am looking for local, but so far no luck.
www.balrgn.com
02-16-2005, 08:20 AM
Old Paint, rolling again.
1973 Argosy 20
Lorain County
, Ohio
Originally Posted by balrgn
I looked at my rims this past week... 2 are in need of replacing.
I'm simply curious, what's wrong with your steel wheels?
Mine even had tubes in them, and looked awful until I sand blasted them. The rust wasn't too bad after all and the bead areas were perfect. POR-15 and a top coat later and they look like new. Now they've been holding air great since I put new GY Marathons on them.
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
02-16-2005, 10:30 AM
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
I'll grab a pick next time I go over to work on them. There is a section on 2 rims that are corroded near the bead. I'm not sure how or why but one of them looks like If I was to hit a good sized pot hole there is a potential to pop the bead.
www.balrgn.com
02-16-2005, 06:03 PM
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Here is a pic of the corroded rim.
After thinking about it. I'll be ordering 4 when I decide which to buy.
www.balrgn.com
02-16-2005, 07:20 PM
Retired.
, At Large
If you decide to get wheels other than from Andy, be sure you get 2600# rated wheels, they should be zero offset, also. It would be a good idea to check that before ordering any wheels.
02-16-2005, 11:28 PM
What is the hole spacing on a 1977 Argosy Minuet?
I want to get new wheels for mine!
All these champagne ideas on a beer budget!
02-17-2005, 04:42 AM
Retired.
, At Large
I have a set of wheels that will fit your coach, PM me, and I will send you pictures.
02-17-2005, 05:52 AM
1973 Argosy 20
Lorain County
, Ohio
That looks like classic "flat tire sat in the mud for 2 years rim rust". BTW: I ordered my tires from lowcosttrailersupply and I thought that the shipping was resonable. But Then again they are fairly local to me being in Ohio also.
Steve
02-17-2005, 06:45 AM
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Placed the order this AM, good to know that you had good luck. Came to $244 for 4 with shipping. Figured that all 4 would be worth the investment. I don't have much background on the AS only that is sat idle for 17 years. The curb side rims look to be scrap. The other 2 are in better shape. I'll use one for a spare.
www.balrgn.com
