Old 08-21-2013, 07:51 PM   #1
1962 22' Safari
Castle Rock , Washington
New(old) 1962 22' Safari
Hi all!
Just bought a 1962 Safari. It has been sitting in a field next to the owners house for 10-12 years. It's like a time capsule. Everything there and very few man tracks. Tires are amazingly not too bad and I do have a spare.
Problem: I need to tow it 300 miles to home base.
Plan A: Remove tires, pull hubs apart, clean and inspect bearings, back off brakes, repack bearings, add tires, cross fingers.
Any advice from you guys who know what the heck your doing?
Thanks.
Tim
By the way, anything worth doing, is worth overdoing!
Tlam is offline   Reply With Quote
Old 08-21-2013, 08:45 PM   #2
pbearsailor's Avatar
Port Hadlock , Washington
Welcome to the forums Tim.
I'd definitely put new tires on it (can't tell from your post if that was the plan). Personally, I'd not get too far into bearings as it might be hard to come up with the proper grease seal. You'll want lights and the easiest way is to take a set of magnetic temporary towing lights with you along with enough wire and a new 7 way plug.
No mention of your tow vehicle so I'd just assume you have a brake controller on it and a 7 way socket for your lights. The trailer should take a 2" ball.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
