I have a 1972 25ft. trade-wind. I need a wheel so I can have a spare. Does anybody know where I can find a used or reasonably priced wheel? What works... it doesn't have to be an "authentic" wheel. Does anybody know the bolt pattern, rim width, and the offset? Also, did this unit come with a spare from the factory and if so, where does it mount?
Welcome to the forums!
Most two axle coaches did not come factroy equipped with a spare tire mounted. The theory is that if you have a flat, you can remove that tire, and limp to a point of repair at reduced speed on three wheels. Airstream sells steel wheels that should fit your coach, they are 6x5 1/2" bolt pattern, and should be zero offset. If you can't gete one from Airstream, you can check Inland RV, they have new wheels also, for about the same price as the factory.
Now, if you just want "one that works", you can get a 15x7 wheel, with the above bolt pattern and offset, in the proper weight rating (should be 2500 pound capacity, IIRC) from Redneck Trailers. They have a website, and you can order one from them. It will be a wagon spoke type wheel, but a spare is a spare.
Note its a 15 x 6 on 5 1/2 center and is rated at 2600 # for $41.
Dexstar makes them and Redneck is also a supplier. In fact if you order from Lowcost... it comes in a box from Redneck Trailer Supply. In our area (NW FL) NAPA also deals with Redneck so you can order them there. And most important for the earlier Airstreams they also have a dogdish hubcap that fits this wheel for about $8.00.
A stock Chevy or GMC 1/2 ton pickup wheel has the same bolt pattern ( 6 bolt ) . You will have to ream out the center hole slightly ( approx. 1/32 ) for the hub to fit . You won't be able to use the center hub from an alum wheel , but it is just a spare . Junk yard specials for a few bucks . Trial fit before you count on it . Good luck
ticki2, What is the weight rating or capacity for those wheels?
What about the factory mags that come on those trucks - will they work, and what are their capacity?
__________________ NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
ticki2,
Sorry , don't know the exact weight rating of the GM wheels . I do know that a GM 1/2 ton pickup has a GVWR over 6000# which is more than a 25' tradewind
Not sure about the mags ( alum) . I think most of those came in 16". It's been my limited experience that after market wheels don't have enough back set ( stick out too far )
The one I found fits exactly like my original alum wheels , lines up front to back . One nice thing about GM wheels is that the 6 bolt pattern stayed the same . It sure would be great to find a GM alum rim with the correct width and back set.
Tedd Ill
AIR#3788
1967/8 Overlander International Twin w/ bunk/s. Yes, four kids and two adults in the thing. Happy wife, happy life.
Be sure to speak to the wheel expert at your local LS. While all of their people are fairly well trained, some are not that up to date on the load rating of their wheels! Better be safe than sorry. (from direct experience with LS)
__________________ Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background ) WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325 TAC# OR-1 CHARTER MEMBER: FOUR CORNERS UNIT
The Gross Vehicle Weight Rating may be over 6000 pounds. That means the wheel rating will be less than that. It is not anticipated that one wheel will have to support the entire truck. I would guess the wheel rating to be between 2000 and 3000 pounds. So it may work and then again .......... (Clint Eastwood) "did I shoot 5 times or 6? Do you feel lucky?"
Also there are other places. Colaws RV in Carthage Missouri. It is 200+ miles from you, and the drive may be worth it. Lot closer than AZ.
>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action , I believe a '75 Tradewind has 4 wheels also , it seems the same reasoning would apply.
Andy , as soon as you mount a wheel and travel on it , it becomes a used wheel . How many miles or years can you expect to be safe before you magnaflux them or replace them?
