Old 05-15-2005, 03:30 PM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Rivet
Originally Posted by markdoane
Backspace sure is easier to understand.
I understand 'offset', but can never remember which side is positive and which is negative. What a bother!
They should sell wheels with backspace instead of offset.
Okay, to get more technical, offset is when the center is outward from zero, inset is when it is when it is inward from zero. Inset and offset sound better (and more technical) than backspace and frontspace.
If you own a later-model Ford van or pickup, most of the factory wheels actually have the inset stamped on them, it would say "inset10" or a similar number.
Old 05-15-2005, 04:01 PM   #16
Images: 59
Lets try this again.
Those terms are not correct. Offset is not the opposite of Inset. The terms are 'Outset' and 'Inset', corresponding to 'Negative Offset' and Positive Offset', respectively.
Most wheel sellers use the positive and negative terminology, so that is what I would use. There is also some confusion, in that Ford also uses the 'inset' terminology when refering to bolt sizes and bolt insets.
Also, Inset and Backspace are different measurements, not interchangeable.
Old 05-15-2005, 09:58 PM   #17
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Inset / Outset explained and illustrated here: http://www.tjtrailers.com/store/wheels.html
So Long!
Bob Thompson is offline   Reply With Quote
Old 05-16-2005, 05:08 AM   #18
Well Preserved
1993 21' Sovereign
[QUOTE=Bob Thompson]Inset / Outset explained and illustrated here: http://www.tjtrailers.com/store/wheels.html [QUOTE] I see where they explain inset/outset, then two paragraphs later, they tell you how to measure offset, which is the same thing. I guess as long as the wheel salesman knows what we are talking about we should be okay, maybe.
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
Important upgrade - Cap Puller Janet H Exterior Restoration Forum 9 04-18-2004 05:45 AM
Plastic Wheel Wells Dennis Interior Restoration Forum 14 01-17-2003 12:05 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
The Junkyard Wheel Story Inland RV Center, In Wheels, Hubs & Bearings 1 04-10-2002 06:04 PM
