Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels, Hubs & Bearings
Old 03-28-2012, 03:35 AM   #1
JGS
1967 30' Sovereign
Saint Augustine , Florida
Need Dexter used (I think) Hub
I had a wheel come off therby sheering all the lugs. I took the hub off and now someone has stolen the hub. Does anyone whos had purchased new axels and wheels have a hub for sale. I am attaching picture of the stolen unit. It is off a 1967 Sovreign. Will any other hub work
JGS is offline   Reply With Quote
Old 03-28-2012, 05:32 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The Dexter hubs were used in later years and had bigger spindles I believe.
A replacement hub off an older trailer should not be to difficult to find. Many trailers used 12 inch brakes so one of an SOB may likely work also.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-28-2012, 05:54 AM   #3
1960 24' Tradewind
Riverside , California
Same spindle as used today, #42, new drum would be a Dexter 8-201-5UC3, 5200# rated 12 x 2, 6 on 5.5"
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 01-14-2023, 03:56 PM   #4
Toronto , Ontario
Hey JGS. I think I have to replace my older wheel hubs on my 1974 sovereign. I believe your original hubs were the same as mine with the threads on the hubs and then the wheel bolts screwed into those to secure the wheel. Did you replace with the 12” dexter hub? Any issues?
HoldenGatt is offline   Reply With Quote
Dexter brake shoes....a problem. ROBERT CROSS Brakes & Brake Controllers 34 07-04-2012 10:51 AM
Need help with twin bed/couch bonuts Upholstery, Blinds, Walls & Interior Finishes 5 04-14-2012 11:28 PM
What Kind of Rivet Do I need? Why Olympic rivets? Kyle-King Ribs, Skins & Rivets 10 03-27-2012 09:47 PM
I need a measurement from a current body-style Suburban! phbarnhart Towing, Tow Vehicles & Hitches 5 03-27-2012 05:55 PM
Need manual for 1994 LY Oshkosh chassis 442 john Land Yacht/Legacy Motorhomes 3 03-25-2012 10:02 AM
