Old 01-21-2017, 01:27 PM   #1
Alhambra , California
n00b questions: Wheel sizes
My first post and I'm almost completely ignorant about Airstreams so show
some mercy!
1. Am I correct in assuming that 15" wheels are standard?
2. Are 16s a factory option?
3. Are 16s the max given the seemingly tight wheel wells?
4. How stout are AS axles? I know that is subjective but I gotta ask.
I ask because I intend to do a lot of boondocking.
Thanks in advance!
snekker is offline   Reply With Quote
Old 01-21-2017, 01:49 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, Mine has 14 inch wheels. I think the only reason to go larger is the increased choice of available tires.
MICHAEL
Old 01-21-2017, 02:08 PM   #3
2014 25' FB Flying Cloud
Hillsborough , North Carolina
65 versus 70 mph, & E rated
Getting above the 65 mph limit and being able to run 70 in certain situations is one benefit.
Getting more safety margin with the E-rated is another.
Like the previous post said: it is about the limited number of choices in the 15.
65 vs 70 might spark all kinds of rebuttal, but even for those that really try to only run 65 might find times they actually occasionally run over slightly over 65. The problem then is they are exceeding the rated speed. Easier to have tires rated above 65 and not worry about those times when looking down and maybe pushing 68 - 70.
GeeSag is offline   Reply With Quote
Old 01-21-2017, 02:13 PM   #4
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . no, depends on length, yes, depends on length, probably, depends on length. . . axles are good, depends on year. . . . . . In other words, no one answer to your questions. Been making these things for years, so lots o sizes, models, features. . .good luck and welcome aboard !. . . Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 01-22-2017, 02:38 PM   #5
The two reasons I want to go larger are to be able to use LT tires
and a little more clearance - every little bit helps when you're
boondocking I would assume.
I've seen where people have put 16s on their Airstreams.
Old 01-22-2017, 02:51 PM   #6
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Larger tires may give you more clearance (1/2"), but will go further up into the wheel well limiting how much you can 'bounce' when boondocking.
You can replace axles with ones with a higher degree of drop, but this raises the center of gravity of the trailer.
Everything is a trade.
If you have an older trailer, they will sag over time - need to be replaced every 20 years or so. This will increase you ground clearance.
I have found the 15" that came with my Airstream is a good compromise - the engineers that designed it may know what they were doing.
Silver Hawk is offline   Reply With Quote
Old 01-22-2017, 03:25 PM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If wanting trailer for boondocking, and rough roads, might look at the Oliver trailer
Total n00b here Rkbarry Member Introductions 7 11-25-2014 04:29 PM
n00b! mistacolin Member Introductions 17 08-19-2013 03:11 PM
1979 31' Sovereign - 100% n00b - Bringing it back to life Gasgano1979 1974 - 1979 Sovereign 1 03-21-2013 07:46 AM
64 Globetrotter - Wheel and tire sizes abruzzi Tires 6 08-04-2005 11:04 PM
Wheel sizes and pricing? Sneakinup Wheels, Hubs & Bearings 14 03-15-2004 03:42 PM
