06-19-2014, 04:57 AM
Hertford
, North Carolina
modern Chevy 6 lug on my '74 Boles Aero?
Yes, i know, this is an airstream forum and I asked a Boles Aero question, but I know the six lug wheelsa on my boles are the same as six lug wheels on Airstreams of that era.
I have an opportunity to acquire four beautiful aluminum Chevy rims that probably came off a Tahoe or some other SUV. THey would look very nice on my Boles.
I'll research the weight issue when i get my hands on them, just wanted to know if the bolt pater is the same.
thanks
06-19-2014, 05:38 AM
Retired.
, At Large
Bolt pattern SHOULD be the same as an Airstream, 6 bolt, 5 1/2" pattern, zero offset.
06-19-2014, 06:05 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
The older chev. 6 bolt pattern was the same so probably that would still be true.
On the steel wheel a grinder was needed to make little more center hole room where the "nubbins" on my 69 hub were.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
06-19-2014, 06:32 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Check the center hole and the offset.
06-19-2014, 06:51 AM
Hertford
, North Carolina
THanks.
For the trailer we want ZERO offset, right? THese rims have a couple inches of negative offset, so the track would be narrowed by 4-6" overall, right?
I've been looking this information up and all i can find for these chevey rims is "standard offset"
I'm thinking I can find spacers for under $100 and that would probably be worth it. (i''ll be getting the rims for next to nothing)
07-22-2014, 04:28 PM
1961 22' Spaceliner
Portland
, Oregon
I just looked into seeing if my 2012 Suburban wheels would fit my '61 Airstream Safari. The bolt pattern is right but the offset is 31mm. Plus they are 17" rims which I assume is too big for the trailer...so I am giving up on the idea that I could have the same wheels as the tow vehicle and share the spare.
07-22-2014, 04:44 PM
1978 31' Sovereign
1984 31' Excella
Springfield
, Missouri
I got my spare wheel for my 78 31' from Redneck Trailer Supply. is was about $55 dollars.
07-22-2014, 11:01 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
A couple of inches is a LONG way to go with spacers.
They would worry me and spoil my comfort.
