07-12-2017, 03:02 PM
Bob & Clestine
2018 27' Globetrotter
Cosby
, Tennessee
Metal Valve stems for a 2017 Flying Cloud with 15 inch wheels
Will TR 416 metal valve stems work with the 2017 Flying Cloud 15 inch wheels? A local vendor provided the information, not sure who manufactures the stems.
Thanks!
07-12-2017, 03:15 PM
1999 34' Excella
Hillsboro
Yes... they should "work" as there are standards.. also get the high pressure ones if possible.
Peace and Blessings..
Channing
WBCCI# 30676
07-16-2017, 07:19 AM
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
A Question: we have a 2017 Flying Cloud and it "appears" to have metal valve stems. Could this be a metal cladding on rubber stems? ... or truly metal stems?
07-16-2017, 07:31 AM
2017 27' Flying Cloud
London
, Ontario
Are these things replaceable by non-experts, or do they need to be installed at a dealer/tire shop?
07-16-2017, 07:39 AM
Hiawassee
, Georgia
I'd go to a tire shop for stem replacement. Stems are installed I think from the inside of the wheel.. gotta take the tire off
07-16-2017, 07:48 AM
1995 25' Excella
xxxxx
, xxxxxx
The tire does not have to come off the wheel. You only have to break the bead on one side. Then you can stick your hand inside to do the swap. I have a Harbor Freight portable tire changer. I swapped the valve stems myself at home.
07-16-2017, 11:36 AM
Hiawassee
, Georgia
Ok, but my point is you have to deflate & break the bead. Then make sure the bead is properly set when you re inflate. That's beyond what most people want to do themselves.
07-16-2017, 02:58 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Thanks!
I've got a 2016 Flying Cloud with 15" wheels.
Same question. But...........
The "tire experts" at CanAm tell me that they're not available.
I want them for my T.P.M. sensors. (they don't weigh much.)
07-16-2017, 06:05 PM
Bob & Clestine
Cosby
, Tennessee
I purchased the metal stems, less than $2 each. Still looking for a good tire shop to do the install. Will post if the ones I purchased worked.
07-16-2017, 07:48 PM
1995 25' Excella
xxxxx
, xxxxxx
I am sure Walmart will do a valve stem swap.
07-20-2017, 09:27 AM
1999 34' Excella
Hillsboro
Be careful about how the trailer is lifted. They can ruin axles or underside
Any reputable tire shop can safely do the job... worth the $ if they don't damage and/or over torque lugnuts
Channing
WBCCI# 30676
07-20-2017, 12:00 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
This just happened a week or so ago to someone...he was even outside showing the mechanic where to lift, but another mechanic quickly starting raising the other side. In the 5 seconds it took the owner to get to that side, the fresh water tank drain valve and surrounding tank cover were smashed in.
How this mechanic thought that was a good place to lift is beyond me.
