Old 10-04-2010, 04:45 PM   #1
2006 16' Safari
Minden , Nevada
Max Wheel Air pressure rating
Greetings to all!
I have a friend who just installed Load Range E tires on her 25' International. Does anybody know what the max. air pressure the stock rims are rated for? I tried looking on the inside of the rim, but could not find it.
A/S Squared is offline   Reply With Quote
Old 10-04-2010, 07:13 PM   #2
BDandTTs's Avatar
2005 22' International CCD
Huntington , Vermont
Images: 49
Our Aluminum wheels are clearly stamped inside (or backside of rim) with the maximum pressure allowed. Maybe his are also, but it would have been better to check before replacing the tires. Keep your fingers crossed.
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 10-11-2010, 02:32 PM   #3
Jackson , Wisconsin
Are the wheels stamped with a max load capacity?
Typically, load capacity and max air pressure go hand-in-hand. So, if your wheel is compatible with your tire, then the load capacity stamped on the sidewall of your tire should be the guideline to use. Be sure the load capacity on your wheel is greater than the load capacity on your new tire.
Hope this helps!
streamair is offline   Reply With Quote
Old 10-11-2010, 04:42 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The Alcoa forged 5 spoke 15x7j wheels are rated to 95 psi on my 2004 Classic SO.
Jack
Jack Canavera
STL Mo.
AIR #56
F150 (max 7000 tow rating) pulling Safari 25? Eckhart Tow Vehicles 9 04-03-2009 07:22 AM
