Old 07-11-2008, 03:37 PM   #1
Images: 59
Match mount Marathons?
I bought a set of new Dexstar wheels and a set of Chinese Goodyear tires. They took about three ounces each to balance with the tires mounted with the red dot next to the tire stem.
This year I wanted them re-balanced to compensate for the Pressure Pro sensors. I thought it would be worth the extra bucks to have them Road Force balanced on a Hunter.
The first tire balanced with zero weight after the tire was rotated 180 deg, which put the yellow dot next to the tire stem.
The second tire took 6.5 oz. to balance with the red dot next to the stem. I had the shop rotate the tire 180 deg. and then the tire balanced with 2 oz.
My recommendation: If you want to match mount Marathons, is start with the yellow dot next to the tire stem. Your results may vary.
Old 07-11-2008, 04:01 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Does your commanding intellect translate into presence?
Out of curiosity, did you just walk over and monitor the technician? Tire shops around here have multiple signs advising, "Walk no further. Our insurance does not allow your QC!"
Or something like that.
The last time I surreptitiously monitored a tire shop, the boy glared at me and boy-handled my Burb's newly-painted appliance-white wheels.
Tom
Old 07-11-2008, 04:23 PM   #3
Images: 59
No I didn't. I've used this tire shop for 30 years, since it was a little hole-in-the-wall and the waiting room was a stack of old wheels next to the air compressor.
Now they are the largest independent tire store in the state and have a flat screen TV in the customer lounge.
I always talk to the service manager and the technician so they understand what I want and how to do it. I don't like people hovering over me either, so I let them do their job in peace.
Old 07-11-2008, 04:28 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Don, FYI, the yellow dot is the light part, it is supposed to be mounted near the valve stem.
Old 07-11-2008, 04:36 PM   #5
TomW's Avatar
1967 26' Overlander
If only Minnesota wasn't so cold
Originally Posted by markdoane View Post
... I always talk to the service manager and the technician so they understand ...
Cool.
I have, as yet, not been afforded that dual opportunity.
Kim's not keen on cold weather or I would think about moving...
Tom
Old 07-11-2008, 05:03 PM   #6
Images: 59
That's true, but I think standard practice at many tire shops has been to mount the red dot next to the tire stem. The red dot marks the maximum radial force point.
I think the red dot preference is outdated. Dexstar, the wheel mfg'g, doesn't mark the maximum runout point (radial force) or the point of lightest weight. They just punch out the tire stem hole at a random point.
180,000 miles on my goodyear marathons! 2airishuman Tires 124 08-06-2010 10:31 PM
Chinese Goodyear Marathons doorgunner Tires 75 07-06-2009 05:22 PM
Flush Mount or Surface Mount Skycop Water Heaters, Filters & Pumps 10 01-13-2008 06:59 PM
China/Canadian Marathons ? Resorts Tires 24 09-23-2007 08:22 PM
What's the best match? Rhonda Awnings 3 04-23-2007 11:30 PM
