Old 06-14-2011, 08:42 PM   #1
greatlakes's Avatar
2004 25' Safari
N/A , Michigan/Florida
Lugnut Cap Spinning
Has anyone had the original AS "beauty" cap over a lugnut spin around the real nut and cannot remove it? If so, how did you deal with it? Cold-chisel it off the nut? Force a 6-pt, deep socket over it with a mallet and try to screw the whole thing off as intended?
Apparently some genious used a 12-pt socket and managed to round off and loosen the cap.
___________________
Frank
2004 25' Safari
2010 4x4 Ford EB Expedition
greatlakes is offline   Reply With Quote
Old 06-14-2011, 08:49 PM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Haven't had to do it with the AS lugs...
What I did with the old TV, cut off cover carefully w/die grinder and get a metric 6 point, should fit well enough to remove.
The solid chrome replacements 'aint cheep.... but not a bad idea.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-15-2011, 06:31 AM   #3
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Also ,looking for this solution. Recently had tire's changed and mechanic said to get rid of the nuts. Which i havn't done yet.
knunut is offline   Reply With Quote
Old 06-16-2011, 04:50 AM   #4
2016 30' Flying Cloud
Oviedo , Florida
Replaced all of mine when I did the 16" conversion this week. You want 1/2"-20, bulge seat, acorn nuts. Depending on brand, they will take a 3/4 or 13/16 socket, so don't mix brands unless you want different wrench sizes. I paid about $30 for 24 nuts (6 packages of 4).
khollister is offline   Reply With Quote
Old 06-16-2011, 05:23 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The 13/16" nuts have a slightly higher weight rating. I'd recommend them, unless the lug nuts are inset in the wheels, and you wouldn't be able to remove them.
Old 06-16-2011, 06:43 AM   #6
knunut's Avatar
2007 20' Safari
Thumbs up Thank's
Sounds Good , New Sen Del T03 Wheels,New 16 Inch Mich and New 13/16 Lug Nuts. Now to Source it all.
Old 06-16-2011, 06:51 AM   #7
What makes McGard lug nuts better? - McGard: Innovative Security Products
PFC
RLC
PVC cap for sewer hose? lovetofly Waste Systems, Tanks & Totes 2 05-29-2011 07:48 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
Aluminum end cap? Breadbug General Interior Topics 1 01-27-2011 09:54 AM
Keep or not? Interior end cap. Breadbug General Interior Topics 1 01-18-2011 04:42 PM
