Old 01-26-2010, 04:23 PM   #15
Guest
I use Permatex "anti-seize" on all my lugs with aluminum wheels. It prevents seizing and galling on dissimilar metals. My 2000/30 excella calls for 80 ft lbs.
searcher is offline   Reply With Quote
Old 01-27-2010, 09:19 AM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Digression: I agree a tread depth gauge is a necessity. It helps identify uneven tire wear quickly (if you use it) and tells you which tires to rotate where. I use mine on all my vehicles fairly frequently. Although car and truck manufacturers tell you to rotate in a standard pattern, I find that doesn't always make sense and sometimes just switching 2 tires instead of 4 or 5 is all that's needed. Back to lug wrenches.
Gene
Old 01-27-2010, 09:56 AM   #17
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Speaking of the original question - when I bought my first AS it came with a lug wrench that the PO had bought. So I never thought about it again.
That is, until I tried to use it on the side of the road; the "sockets" were too fat to fit around the lug nut and between the center chrome hub cover. I always carry a pretty full wrench and socket set, so I had a good plan B, but that could have been a real problem. So yes - you must be careful about which speed wrench (lug wrench, cross wrench or even socket). Test them before you need them.
Pat
pmclemore is offline   Reply With Quote
Torque wrench..necessary? Kistler Wheels, Hubs & Bearings 20 08-01-2016 06:15 PM
5 lug vs 10 lug wheels rollin home Wheels, Hubs & Bearings 0 08-03-2009 02:23 PM
Lug wrench incl. with AS is useless temcotom Wheels, Hubs & Bearings 18 10-30-2004 11:22 PM
$28.99 for a torque wrench... did I was my $ Kistler Our Community 3 03-11-2004 06:27 PM
Wrench Sizes rmmm68 General Repair Forum 1 01-14-2003 01:05 PM
