Old 10-29-2004, 08:18 PM   #15
Question '76 overlander rim
Anyone know what type of jeneric rim would fit my old 1976 28 ft. overlaneder? Need one for spare tire. Is that dealer item only?
rockcutter is offline   Reply With Quote
Old 10-29-2004, 08:45 PM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Your manual might point out that you can remove a flat on a two-axle trailer and tow at less than 40mph to any service facility. The bad tire will suspend off the ground if you can push/pull the good tire/axle onto a small ramp. Remove the bad tire/wheel and pull your trailer into town. Such a ramp can be home built from layers of a few short 2x8s or the type you can buy at auto supply. The 2x8s can double as levelers for camping if you devise a system to lock variable numbers together.
I know you need to pay attention to the capacity of the rim. For instance, look at The Story of the Junkyard Wheel. Your question has been the topic of a few older threads if you are better at the 'Search' function. Okay folks! The question is still out there -- wheel knowledge please.
5 meter Langford Nahanni
Old 10-30-2004, 10:54 AM   #17
rockcutter -- Have you run across the wheels or Rims posts yet. Post any further question under those posts and you just may get some of those participants helping you.
Old 10-30-2004, 01:20 PM   #18
Cracker's Avatar
Pittsfield , Maine
I definitely re-torque after about 100 miles and yes, I have found noticeable changes in the torque values. I think, however, that the dual wheels on the truck are more prone to loosen than the aluminum wheels on the trailer. It may just be the higher torque requirement for the truck (140 ft-lbs) as opposed to the trailer.
As an aside, I waited until I had 1,500 miles on the truck - just after I bought it - before checking the torque on the wheel lugs. There wasn't a single wheel with the correct torque -and I remember, in particular, that the right front was downright loose. The mechanics at the GMC dealership I stopped at didn't have a clue about what the correct torque should be. They simply wanted to apply the air wrench they always used - since no one had ever asked them to check torque (---furthermore, they had no idea what the air wrench was set at!) My next stop was at NAPA to purchase a torque wrench, an extension to reach the dual lugs, the correct socket, and a breaker bar. I also carry an extra long star-type lug wrench, and ramps to roll the trailer up on to. The only thing I wish that I had, or that I could carry with me, is a set of four stands that would permit me to do a 7-tire rotation on the truck. I'll gladly pay a competent garage to work on my truck - but I'm finding that the word "competent" seems to be disappearing from the English language! Nowadays, I cringe when I have to take the truck in for service.
Cracker
Cracker is offline   Reply With Quote
Old 10-30-2004, 11:22 PM   #19
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I too have found some of the lugs loosen as the initial miles have gone by after a remount.
The actual practice from what I've been told is that alum wheels (any vehicle) need to be re-torqued after a few hundred initial miles after being mounted.
Also while on the subject of tires, it's very important to keep an eye on the proper tire pressures as well....to that end, I also keep a tire pressure gauge with me.
Lug Bolt Size for '78 Sovereign dinoburb Wheels, Hubs & Bearings 2 03-20-2004 03:34 PM
lug bolts Chas Axles 3 02-18-2003 09:55 PM
Wrench Sizes rmmm68 General Repair Forum 1 01-14-2003 01:05 PM
newbie looking to buy Oak All Argosy Trailers 13 10-11-2002 10:17 PM
In need of an appraisal escapeez Our Community 27 08-24-2002 06:52 AM
