Old 04-11-2011, 07:04 PM   #1
2008 28' Safari SE
Punta Gorda , Florida
Lug socket size
I just purchased a 2008 28' Safari which is located 100 miles from where I live. I plan to pick her up next week but before I do I want to be prepared to fix a flat should the need arise. I have a ramp but need a tourque wrench and the proper sized and style socket. It would be helpful if someone could tell me the correct socket size and style of socket. I believe I read I need a thin walled long socket. Are there considerations when buying a tourque wrench other than a long handle? I will have a breaker bar for more leverage. It appears from the manual I need to tourque to 110 LB.
Thanks for your help.
John Dibble, Punta Gorda, FL
mysecondjoy is offline   Reply With Quote
Old 04-11-2011, 07:19 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
My trailer uses a 3/4" lug nut. Because of the thin chrome cover on the nuts it is important to use a six point socket. A deep socket and 10" extension work best.
Old 04-11-2011, 07:34 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
It is important to carry a breaker bar as well as a torque wrench. While some torque wrenches will lose calibration when used at the high torques sometimes necessary to remove a stuck lug nut, the real problem with cheaper ones is that you may shear the teeth off the ratchet rendering the wrench useless (ask me how I know).
Old 04-11-2011, 08:04 PM   #4
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
If you also plan for fixing flats or anything else along the road, bring a set of road triangles and a reflective safety vest...
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
Newbie question - decorative lug covers idmtman Wheels, Hubs & Bearings 9 02-05-2011 11:41 AM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
