Old 09-26-2005, 03:32 PM   #1
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Lug Nuts - Tires
Is there a plastic cap on the newer Airstreams lug nuts?I was attempting to check the lug nuts to see about tightening them and it seems that there is a plastic cover over the lugs.Am i wrong?If not,How do I take these off to get to them.Thanks.
I tried looking in the manual but there is nothing on this subject.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 09-26-2005, 06:04 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I can't swear to this, but many lug nuts that come with alloy wheels have a stainless steel cover over the hex. This cover does not come off. Or, I should say, it is not supposed to come off.
It is of paramount importance that you use a deep socket that slips all the way over this lug nut. Make sure the socket is of the correct size. If you try and use a short socket, or in certain cases even a wheel cross wrench, then you might shear off the lug nut, or at least the stainless covering.
It is also always a good idea to re-torque the lugs after having the wheels removed at least once after about 100 miles or so.
I set my torque wrench to 110lbs.
Uwe
www.area63productions.com
Old 09-26-2005, 07:13 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Thumbs down
Yes, I've been looking at doing a reply to the '2006 Quality' thread and this is one of the few issues I have found! Think you have a loose nut? No! It's the stupid sleeve rotating because it is not in close contact with the underlying nut. I would gladly pay 4*,*** + $40 to get real honest-to-goodness stainless steel nuts. This is getting just a bit too chintzy!
Bet the SOBs might try to get away with this -- but I'm not sure I want to bet against the SOBs on this one.... Shame Airstream! Do we believe that Jackson Center lurks around these forums? I would invite a reasoned reply. I am willing to pay for the "upgrade" -- anybody with [name your least favorite Big 3] alloy wheels wouldn't find such a ruse on an economy car.
5 meter Langford Nahanni
Old 09-26-2005, 07:27 PM   #4
Devoman's Avatar
Lugs
So I am able to replace these lugs with better ones as long as I get the right size or are they a special lug for this type of abuse?
Old 09-26-2005, 10:06 PM   #5
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
No need to replace the lug nuts. They won't rotate or rattle unless they have been abused.
Just buy a decent lug wrench for the trailer. Or an deep impact socket and a breaker bar.
Steel lug nuts will look dingy very soon against a nice clean alloy wheel, which is why they do the stainless covers.
I have never seen lug nuts made from stainless steel.
Uwe
Old 09-27-2005, 07:08 AM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
The lug caps stay on. They may work loose a bit, but that doesn't mean that the lug itself is loose. I posted this on the '06 QC thread and would suggest to anyone that a good torque wrench is purchased and carried as part of the basics when you travel. You can read the full post here and it is post #41:
http://www.airforums.com/forum...t=16147&page=3
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
61 Tradewind tires lee_jachter Tires 11 10-04-2002 12:00 PM
Whitewall Tires 66whitebread Tires 0 09-17-2002 06:29 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
