Old 09-06-2016, 03:46 PM   #1
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Lug Nuts and valve stems
I'm going from 15 to 16" Sendel rims on my 2017 25FC, but not sure about the lug nuts. I'm not sure what kit to buy for the nuts if someone can help with size, specs etc. also are the stock valve stems they use at pep boys, etc ok to go with? Also looks like the hub cap will work with 16" rim. Thanks
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 09-06-2016, 04:35 PM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Got our lugs from Amazon
Our Alcoa wheels came with aluminum valve stems....the best option.
Name:	AS STUFF 012.jpg
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-06-2016, 06:19 PM   #3
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
McGards, 1/2 inch 20 thread size are the lugnutz of choice.
Mike
Caffeinated is offline   Reply With Quote
Old 09-06-2016, 06:51 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I put new tires on my trailer last summer. I used high pressure rubber pull thru valve stems. They have a brass core and were what my trailer came from the factory with. The held air fine for almost a year. During one trip, I found a tire totally flat. No punctures. I aired it up. It held air for days. I couldn't leave it alone, though. I went over the tire with soapy water. I found if I pushed the stem sideways it would leak....I broke all four tires down at home and put in bolt in metal valve stems after that.
CRH is online now   Reply With Quote
Old 09-07-2016, 12:12 PM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
AccuWheel LNA-12000C6 Chrome Bulge Acorn Wheel Lug Nuts (1/2"-20 Thread Size) 1.4" Tall - Pack of 24 Lugnuts
Sold by: JK Collection
$19.99
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 09-07-2016, 01:37 PM   #6
Thumbs up
One thing I did learn with the aluminum valve stems....use plastic or aluminum valve caps.....AS felt that a base metal cap would do. First time I checked the AP they were frozen on, vice grips and chase the threads with new aluminum caps.
PFC
RLC
Old 09-07-2016, 06:38 PM   #7
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
So has anyone come up with brass or stainless steel valve Stems? (The better to hold that mithical TPM sensors that actually work as promised.) )
MelGoddard is offline   Reply With Quote
Old 09-07-2016, 07:34 PM   #8
Question
I've see the Brass on ebay, maybe try a truck stop.
PFC
RLC
Old 09-08-2016, 10:22 PM   #9
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
For metal valve stems, I recommend Dill VS-902-W.
You may be able to get them from a Discount Tire store, that's where I got mine. Not listed on Amazon. Be careful of Chinese knockoffs.
Greg
greghoro is offline   Reply With Quote
Old 12-14-2016, 08:49 AM   #10
the woodlands , Texas
What size are the lug nuts on a 25 FC 2017? How tight do I torque them? Have not picked up my baby yet. Just trying to get the tool box fitted out. Thanks everybody.
Leslieotr is offline   Reply With Quote
Old 12-14-2016, 10:19 AM   #11
m.hony's Avatar
2013 30' Classic
Is it 50 ft. lbs. of torque?
TAC #MS-10
Airforums #70955
Old 12-14-2016, 01:19 PM   #12
malinois38's Avatar
2008 28' International
Happy Valley , Pennsylvania
I believe it is 110lbs torque for the wheel lugs.
malinois38 is online now   Reply With Quote
Old 12-14-2016, 02:50 PM   #13
1976 31' Sovereign
Oswego , Illinois
Def. metal valve stems in trailer use, they bolt in and have rubber grommet that seals and protects rim in and out from metal stem and nut damage. Only way to leak if not installed properly. Readily av. at auto part stores and many other places. They do not have to be aluminum . I do not trust high pressure rubber stems with metal inserts and cannot have break downs w/expensive construction and off rd. equipment and exp. AS.. Use short stems if av. as long can get knocked off, but only happened 1 time when off rd. I believe 110 pds. for aluminum rims 55 for steel but check specs with manf. and watch tire shops as they use impact wrench and some times tighten to much.
Old 12-14-2016, 02:55 PM   #14
1976 31' Sovereign
Oswego , Illinois
Smile
I have pur. brass stems many places for my off rd. eqp. as cannot have rust or rubber, they also have brass chrome plated stems. I use chrome plated brass stems on AS
Converting from lug bolts to studs and lug nuts tim781996 Wheels, Hubs & Bearings 7 11-22-2014 10:23 AM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 09:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 03:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 10:41 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 05:41 PM
