Old 08-16-2014, 12:50 PM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Lug Nuts
Will these lug nuts fit the stock 14 inch aluminum wheels on a 2006 Safari LS 23?
Robot Check
Not sure why it says Robot Check, but the link is good.
MICHAEL
Old 08-16-2014, 01:01 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Looks right. I wonder is Napa or another tire place could help out...
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-16-2014, 01:24 PM   #3
interstateflyer's Avatar
2017 25' International
Los Osos , California
Robot Check
I replaced the 1/2 inch wheel nuts on my new International 23 D last week when I went from 14 to 15 inch wheels and tires.
Half of the nuts were cracked on their outer shell. Price at America's Tire/Discount Tire was $35 for 20 shiny new ones.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 08-16-2014, 02:14 PM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
That outer shell is just a decorative bright cover to look good with your aluminum wheels. It will be a hassle when / if the outer cover gets stripped and your lug wrench slips on it. In a pinch it can be removed ( yes, it happened to me) by cutting it with a small sharp chisel and tearing it off. You can then use an appropriate sized socket to remove it. These work well until they don't. There are better ones out there. If your new ones are of similar design you might be wise to carry a small chisel and a pair of side cutters in your toolbox for that moment that might never come.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-16-2014, 04:42 PM   #5
AWCHIEF's Avatar
Images: 33
I recently had my tires replaced. Most of the nut covers came off or had to be taken off by the shop. Cheap pieces of crap. More example of cost cutting by Thor/Airstream. I have found several local places that have quality replacements at reasonable prices.
MICHAEL
Old 08-16-2014, 05:01 PM   #6
AWCHIEF's Avatar
Images: 33
OK next wheel question. Where can I purchase the center wheel covers? I am missing one.
MICHAEL
Old 08-16-2014, 06:45 PM   #7
No. 13's Avatar
2012 25' FB Flying Cloud
Orange County , California
Interstateflyer... What was the part number that you ordered? Thanks.
No. 13 is offline   Reply With Quote
Old 08-16-2014, 08:32 PM   #8
retired USA/USAF
2001 30' Excella
Hey Chief. Check online with any wheel supply place. Measure so that you know the size. I think you can get them in chrome or SS.
Roger in NJ
TAC - NJ 18
Old 08-16-2014, 09:16 PM   #9
They forgot to put them on my original invoice with the wheels and tires so I didn't see a part number when I paid separately.
I'd take one of your wheels nut to the supplier and have them match. get as high quality as you can.
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
Rusty chromed lug nuts nickcrowhurst Wheels, Hubs & Bearings 14 08-02-2004 06:52 AM
lug nuts bambi david h Axles 2 02-10-2003 08:59 AM
