Old 12-05-2013, 09:13 AM   #1
2009 27' FB International
Silsbee , Texas
Lug Nuts
I just ordered the Sendel 16" T03 wheels. Can or should I use the stock lug nuts on the new wheels??? Our trailer is a 09 27' International dual axle with the OEM wheels. Here's a pic of the OEM wheels.
Craig Schrader is offline   Reply With Quote
Old 12-05-2013, 09:24 AM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Imho......
.....new wheels new nutz.
Get rid of the OEM cheepies and go with the best.
None of that chrome cap crap, solid quality.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-05-2013, 09:30 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Also have them install metal valve stems, not rubber like the originals.
Doug and Cheryl
Old 12-05-2013, 09:47 AM   #4
Missouri Valley , Iowa
Craig,
I just got new 16" wheels with Michelins for both my trailers. Bob is right. For a few bucks more why not eliminate all the doubts on lug nuts and start with new? One set of my wheels look identical to yours. Its a good choice!!
Dan
Farmer Dan is offline   Reply With Quote
Old 12-05-2013, 09:57 AM   #5
Doug
That is something I also had them install on my wheels. Seems like it would be safer than rubber stems. The originals on my '02 had metal stems also.
Dan
Old 12-05-2013, 09:59 AM   #6
Silsbee , Texas
Robert: Reading other threads looks like McGard is the Lug Nut of choice, Thanks.
dkottum: Ordered the metal stems when I made the order.
FYI: Ordered five 16" Sendel T03SM (silver machined), caps and metal stems, with Michelin LTX M/S2 225/75R 16 E Tires, mounted balanced at local Discount Tire shop for $2030.00 with road hazard. Probably not the best price, but a very easy transaction close to the house.
Also I checked Discount Online and was told No they could not order the wheels. Local Discount store could and priced matched Tredit.
Old 12-05-2013, 10:13 AM   #7
Silsbee , Texas
I Plan to order the Centramatic balancers also. All information came from Airforums for the equipment ordered, Thank You all to thoese who did the due dilligence on this equipment!
Old 01-12-2014, 04:47 PM   #8
2004 28' Classic
austin , Texas
Lug nut specs
If ordering new lug nuts, when switching to the 16" Sendel wheels, how do you figure out the size/style of lug nut to order? There are so many options. Someone mentioned they had ordered:1/2-20 McGard #64010Ė stainless steel. Is this the right size/type? I understand that stainless is the way to go - but these appear to be chrome or at least chrome coated, and I thought that was what was wrong with the OEM lugs?
Ntex is offline   Reply With Quote
Old 01-12-2014, 05:09 PM   #9
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
It has been said, but do order new caps, too. They don't come standard with the wheels. I had a little trouble locating them but found some on ebay.
field & stream is offline   Reply With Quote
Old 01-12-2014, 05:13 PM   #10
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I got these lug nuts from Amazon:
McGard 24138 Chrome Cone Seat Wheel Locks and McGard 64010 Chrome Bulge Cone Seat Style Lug Nuts (1/2" - 20 Thread Size)
I will install the 16" wheel size only specific Centramatic wheel balancers part number :
Centramatic 300-356 all A plates for 16" rims
Note that the smaller Centramatic 200-221 Special is for 15" rims, but will fit the 16" rims.
The Michelin LT225/75R16/E LTX M/S2 tires (Michelin part number 05681) will be mounted to four SenDel Aluminum T03-66655T wheels and one SenDel S62-66655TG galvanized spare wheel after the Dill 1506-453 TPMS sender units are installed on the wheels. I have a fifth aluminum wheel in the it's box just in case.
switz is online now   Reply With Quote
Old 01-12-2014, 05:18 PM   #11
2004 28' Classic
austin , Texas
Thanks for all the specifics!
