Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels, Hubs & Bearings
Old 03-14-2011, 09:53 AM   #1
blickcd's Avatar
Milford , Ohio
Lug nut torque for aluminum wheels?
I bought some aluminum wheels from Airstream, same as are used on the 2011 Classic Limited trailers, to replace some old steel wheels on my '79. Also got the closed end lug nuts.
With the old steel wheels, lug nut torque was 90 - 95 ft. lbs. Any difference for the aluminum wheels?
I also noticed that the aluminum wheels don't leave much clearence around the lug nuts. You can get a deep socket on them but not a standard 4-way lug wrench.
Any special thin-wall lug wrenches available or just use a socket and long handled breaker bar? Is using an air impact wrench use okay?
Christopher
blickcd is offline   Reply With Quote
Old 03-14-2011, 10:05 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I use 95 ft lb on the lug nuts on my aluminum wheels.
I have not been able to find a tire cross that will fit and the mismatch is large enough I don't want to try to grind it down. I carry a breaker bar and socket.
An impact wrench is fine for removal but shouldn't be used for installation. Even with the special torque-limiting sockets the results are too unpredictable.
Old 03-14-2011, 10:19 AM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
For quite a few years the torque was 120 lbs. During the 2008 model year Airstream changed wheel suppliers and the torque was supposed to be 110 on those. When I got 16" wheels through Airstream I was told 110 for those. I found somewhere on the Airstream website the information about when in the 2008 model year they changed the torque. The owner's manual for 2008 still said 120.
Gene
Old 05-01-2011, 10:58 AM   #4
1965 22' Safari
California , Kentucky
I just purchased steel wheels from Inland RV 15" what should I torque the lugs to?
RiverRat is offline   Reply With Quote
Old 05-01-2011, 06:44 PM   #5
Master of Universe
Gene's Avatar
Ask Inland Andy on the Forum or call Inland.
Gene
Old 05-01-2011, 08:08 PM   #6
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
I use an impact wrench to remove them. I use my fingers and Torque wrench and deep well socket to put them on.
06 15" Aluminum 110 ft-lbs
Michelle TAC MT-0
Sarah, Snowball
New wheels for '76 Sovereign Hummer Wheels, Hubs & Bearings 11 08-09-2011 06:15 PM
'62 Overlander Lug Pattern CDA62 Exterior Restoration Forum 4 02-17-2011 09:15 AM
Newbie question - decorative lug covers idmtman Wheels, Hubs & Bearings 9 02-05-2011 11:41 AM
Replacing Steel Wheels with Aluminum Daystreamin Wheels, Hubs & Bearings 8 02-03-2011 11:27 AM
Putting modern wheels on a '79 blickcd Wheels, Hubs & Bearings 1 01-21-2011 10:16 AM
