Old 07-06-2003, 05:42 PM   #1
Lug Nut Torque
I have just acquired a 1985 Sovereign (25 ft) without a manual. I am wondering if anyone has information on the correct torque for the wheel nuts.
alan is offline   Reply With Quote
Old 07-06-2003, 06:54 PM   #2
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
The bolts on my '74 are stamped 90-95 ft lbs.
somefun is offline   Reply With Quote
Old 07-06-2003, 06:55 PM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Alan
90 to 95 should be correct
Ken J.
Ken J is offline   Reply With Quote
Old 07-07-2003, 05:05 AM   #4
Lugnuts
Thanks very much.
Old 11-06-2006, 06:10 PM   #5
2007 25' Safari FB SE
Lake Forest , Illinois
Lug Nut Torque
When I picked up my new Safari this week the dealer advised me to check the torgue of our lug nuts every so often. He said they shoul be 110'. I puchase a torque wrench but found out that due to the interior wheel location I would require an extension for the wrench which means that the wrench has to be adjusted for the distance of the extension. How often do I need to do this and is there any easier method????
woodedareas is offline   Reply With Quote
Old 11-06-2006, 06:13 PM   #6
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Relax, the loss of torque for a 10 inch extension is in the noise for the torque you will be applying. Set your wrench for 110#'s and you will be fine. Follow the manual specs for the pattern you need to follow for the lug nuts.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 11-06-2006, 06:18 PM   #7
1975 27' Overlander
High River , Alberta
torque check frequency
A heavy truck mechanic I know (neighbour's son-in-law) once mentioned to me that whenever wheel nuts are re-installed, they try to do a torque check after about 60 miles of travel. They do not loosen the nuts, but simply set the torque wrench and ensure that the nuts are at least as tight as they are supposed to be.
I suppose the torque wrench should be part of our travelling tool kits.
AlbertF is offline   Reply With Quote
Old 11-06-2006, 06:21 PM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There is a formula for determining torque reduction over extension length, but for a relatively short extension, and a relatively high torque, it won't be a major issue. If you feel better about it, you can torque to 115 lb/ft, and be really close to what torque should be without making a lot of agebreaic calculations.
You should check the torque at 10, 50, 100, 250, 500, and 1000 miles.
Old 11-06-2006, 06:28 PM   #9
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Not to dispute...BUT...
Hello woodedareas, I am in no position to dispute what your dealer recommended. But in the latest Blue Beret magazine on page 9, there is A Safety Note from Herb Quade, WBCCI # 3575 stating; "It has been brought to our attention that quite a few aluminum wheels have failed due to excessive torque on the lug nuts. A good guideline to follow is 85 foot pounds unless otherwise specified and check the torque after driving about 50 miles." This statement is an entire quote from Herb Quade.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 11-06-2006, 06:32 PM   #10
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Good point Silverhobby, this was an issue with a Ford recall on F150's a few years back. Seems a pnumatic lug nut robot at a plant overtorqued allot of aluminum wheels and they cracked at the hub. Follow the manuals suggestions and specifications.
Old 11-06-2006, 06:43 PM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We set ours at 115 foot pounds and check it about once a week. We have found that things stay right if you keep checking it. We do the same thing with our Hensley at 45 foot pounds and have have found that this nneds checking more often that the lug nuts on the trailer wheels. Be sure to check tire pressure also. This is Very important.
SuEllyn & Brian McCabe
Old 11-06-2006, 09:35 PM   #12
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
This is a good idea. I picked up my 06 Classic 31 in NC and towed it back to VA. I checked the torque when I got home. One of the nuts was loose and about to fall off. Some were lower than they should be, others were fine.
Check them often when new. Before each trip is a good idea as well....
Michelle TAC MT-0
Sarah, Snowball
Old 11-06-2006, 10:21 PM   #13
1960 24' Tradewind
santa barbara , California
This problem is seemingly specific to trailers with aluminum wheels .Ive followed alot of threads on this ,and its not a steel whell problem. I do not
recommend going 115 ft lbs ,when torqueing any fastener more is NOT better.
already we have too many incidences where these wheel studs are breaking
off with the aluminum wheels .I do say to check them as routine ,but not give
them a " little more " each time unless they are below the torque value as
each little bit more just to be sure can over torque and stretch the stud and
it can break .What really bothers me is that these wheels seem to be so
problematic on these trailers .I work with car and truck aluminum wheels
everyday constantly ,Never are the aluminum wheels / nuts ever loose .
never had any aluminum wheel on a honda ,nissan, toyota ,or chevy suburban ,chrysler ,or ford come off the vehical ,so this deal with these
nuts being loose is a concern .Has anyone ever bought a new vehical and
drove it home and retorqued the wheels once a week ?? does anyone check
the wheels on their civic before they head off to a trip somewhere? Nope
and they shouldn't need to .I don't like the whole idea of this thing with
these aluminum wheels coming loose . Its not right .
Scott
scottanlily is offline   Reply With Quote
Old 11-06-2006, 10:30 PM   #14
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Torgue
I know someone who had an expierience with having the lugs overtorqued.It stretches the bolts itself also if to much pressure is pulling on it.When pulling your camper the weight and unsmooth roads can eventually break one and the domino effects starts happening.Next thing you know your tire is in your Airstreams bedroom from being slung so hard off the hub.I sure dont ever want to go down that road.I think 85 pounds is perfect if that is what they say to do.If you want to be safe go to 100 pounds.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Lug Nut Socket Help... AZstreamin Wheels, Hubs & Bearings 20 09-21-2006 06:04 AM
Strange nut Pahaska Windows & Screens 2 10-22-2002 12:47 PM
In need of an appraisal escapeez Our Community 27 08-24-2002 06:52 AM
Charging AC on 71 overlander smily Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-25-2002 05:33 PM
