Old 08-16-2016, 06:41 PM   #1
2016 28' Pendleton
East central , Illinois
Lug nut problems on 16" wheels
In preparation for an upcoming trip, I checked my lug nut torque today. I found that some of the lug nuts, which are a two-piece construction, had the outer jacket spin on the interior nut, making the nut too large for the socket. This made it damn near impossible to remove or tighten. I had to drive a 12 point socket onto the nut in order to remove the offending nuts. Fortunately I was able to find one-piece lug nuts at the local Napa store. They only had 20 on hand, but will have the other 4 in in the morning. Just wanted to see if this is a common problem or another one of those "No, Bob, just you" moments. Seems a shame AS would not opt for a quality part in such a critical location.
GinaNBob is offline   Reply With Quote
Old 08-16-2016, 06:51 PM   #2
2016 26' Flying Cloud
Southlake , Texas
I recommend using a 6-pt socket on the AS lug nuts and make sure it is the correct size. I messed up on of mine with a 12-pt socket. By just catching on the points, it slightly deformed the outer cover.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 08-16-2016, 06:59 PM   #3
2016 28' Pendleton
Thanks for the reply. I started with my 6 point but when I couldn't get it off I had to resort to the driving on the 12 point. My concern is with the two part construction of the lug nut. I know that this to make it look pretty. I have a feeling that the person who originally put them on got a little sloppy with his impact gun causing the problem in the first place.
Old 08-16-2016, 07:17 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Hello Bob
Neither the two piece lug nuts, nor mechanics' frustration with them, is unique to Airstream. I have a 2006 Dodge Charger that has them, and I've replaced many.
In general it is best to use a 6 point socket, and hand tools, on these. Impact tools, and 12 point sockets, are to be avoided. It is also important that the size match exactly. I'm unsure of the situation with your trailer, but in general, the 3/4" and 19mm sizes are nearly interchangeable but the proper one should be used.
Old 08-16-2016, 08:31 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Bottom line is that the OEM Aistream lug nuts are junk. They work better with a six point socket, but they are still junk. I would highly recommend that they be replaced with McGard solid lug nuts. This is what I have done on three different Airstreams.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 08-17-2016, 06:26 AM   #6
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
So I was looking at installing locking lug nuts on the 2005 classics with a nice set of 16" rims and Michelin tires the PO installed . I have not tried to remove the lug nuts thus far but was thinking about checking the torque and installing the keyed lug nuts..
what size or other info for the McGard lug nut can you provide.. In looking at the website i see a M12x1.25 cone, non cone etc.. any tips or size needed..
Brian
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 08-17-2016, 06:31 AM   #7
2016 28' Pendleton
I am not sure about yours, but mine were 1/2-20 with a 60 degree cone. I have 16 " Michelins on aluminum wheels.
Old 08-17-2016, 06:50 AM   #8
2016 25' Flying Cloud
Holly Springs , Mississippi
Google the McGard 64010 lug nuts and see if that will work. They are 1/2"-20, 1.4" tall nuts. May also wish to consider the Accuwheel LNA 12000C6.
Airstream knows there's a problem with the current lug nuts. Per my conversation with a Factory Tech Rep, they're now considering a change to a one-piece lug nut.
With the OEM nuts, you need to use a 6-point socket of the correct, exact size, then be certain the socket is fully seated (all the way in) before applying pressure.
On my new unit, one lug nut was stripped and five were cracked, as delivered from the Factory. I replaced all with McGards. Money well spent...
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 08-17-2016, 07:35 AM   #9
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I too had a problem with the outer jacket spinning when trying to get the original lug nuts off so I could switch to the McGard 1 piece lug nut. After struggling to get a few off I finally was successful. Then someone told me when this happens you could tap on the outer jacket to flatten it out so the outside jacket would quit spinning. I never tried to do this myself but I wished I had known to give it a try when I was struggling to get them off.
Hiho Silver is offline   Reply With Quote
Old 08-17-2016, 11:42 AM   #10
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Beat a six-sided socket onto them to get them off.
Then replace them with single piece chrome lug nuts.
Frustration over-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-17-2016, 12:03 PM   #11
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Exactly. I had the same problem after 3 blowouts on GYM's and had 4 lug nuts separate. Bought all stainless lugs.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-17-2016, 12:35 PM   #12
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
2 piece lug nuts don't rust. One piece lug nuts do rust. Impact wrenches are the enemy of both. They separate the 2 pieced ones and exacerbate the rust problem on solid ones. Having had numerous Airstreams and others and I have been exasperated a time or two with this issue. It is very tempting to use an impact wrench on a triple axle, but I have tried not to for this very reason. Even if you spend the big bucks on solid, high quality nuts, steel from your socket can transfer to the pristine surface and start rusting. Try to use the colorful, non-marring sockets when you can. I just recently installed new axles and wheels with new expensive nuts. X36 One is already rusting. Oh well.
fwjumper is offline   Reply With Quote
Old 08-17-2016, 12:41 PM   #13
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Get a set of Gorilla's lug nuts the best on the market.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 08-17-2016, 01:25 PM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
TETO....I prefer Mcgard
, made right here in WNY
Got ours from Amazon
........8yrs no rust yet.
Name:	AS STUFF 012.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
5 lug vs 10 lug wheels rollin home Wheels, Hubs & Bearings 0 08-03-2009 02:23 PM
Lug Nut Size?? Steve Heywood 1997 -2001 Excella 3 08-16-2005 12:24 PM
Lug Nut Size AYRSTRM2 Axles 0 08-17-2004 12:27 PM
