Old 09-25-2012, 02:04 PM   #1
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Lug nut mystery
While replacing bearings on my 93 Excella I discovered 2 different lug nuts on the rig, just bought it last year. I know the thread is 1/2 X 20 but the cone angle is the question. Auto stores list two, 60 or 90 angle plus a myriad of depths. Does anyone know which is the correct lug nut, sizes, the dealer says the info they have stops before 1993.
arcamedies is offline   Reply With Quote
Old 09-25-2012, 02:18 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
If the hole is chamfered, then use the 60* nut. If the hole has a square edge, use the 90* nut. The depth doesn't matter unless the lug is closed in which case just make sure the lug is deep enough to accommodate the stud with a little to spare.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
